Results 1 to 5 of 5
Thread: Getting ready, need help calculation TCNC
    Registered slp_prlzys's Avatar
    Mar 2004
    I finally finished my frankenstein machine,
    I want to try turbocnc with it, but I'm
    having trouble with configuration
    (maybe I should be in TCNC forum)
    I tried tcnc before when it was v3,
    and I only have single start screws.
    Now using v4 but with multistart screws.
    These are the screws I have for use with (a very appreciated gift) g201's
    X= 4 start 8TPI
    Y= 4 start 8TPI
    z= 2 start 4TPI
    my pitches for X & Y would be .125 right?
    does the number of start affect the calculation?
    with 10 µStep is .00003125 correct?
    thanks.
    mhel
    "This is intentionally left blank."
    Mar 2003
    Shelby Twp, MI....USA
    by TPI you mean threads per inch, not turns per inch, right?
    If threads per inch, the pitch is .5 for all the screws.
    Mar 2004
    TPI thread per inch yes.
    in TCNC I should put .5 on the space for TPI?
    Can you elaborate on how you get the pitch.
    thanks.
    mhel
    Mar 2004
    darn it, you divide the number of start by the #TPI .Duh!
    mhel
    Mar 2003
  • Posting Permissions
