Results 1 to 5 of 5
Thread: Linear Motion Force Debate
    May 2003
    flint,mi
    Here's another one.
    This is the possibilities of (again, lack of better terms) linear force application.
    Not as many possibilities, anyone have any other ideas.
    In so far in my reading here it seems everyone approves of the dual threaded rod method. What's your opinion?
    Attached Thumbnails Attached Thumbnails Linear Motion Force Debate-linear-motion--force.jpg
    Apr 2003
    USA ofallon, Mo
    Dual threaded rod method would have more rotating mass and 2x the friction so you might need a bigger motor I would use a single inless it was a large gantry
    Nov 2003
    Western KY
    You'll need to make sure that their timed properly. Other than that I don't forsee a problem. The extra rotating mass is small compared to the mass of what you'll be moving added to the force of cutting.
    The only reason that I can see for the dual shaft drive is if you have to drive at each end to avoid racking because you can't figure a good way to drive from the center, or you still have racking problems driving from the center. What do you have in mind for your machine, do you forsee a problem?
    Another thought is, that if you used large diameter drive rods, you may not need the linear bearings at all.
    mike
    Registered balsaman's Avatar
    Mar 2003
    dual threaded rods are best for precise work. The rack and pinion is great for high feedrates but a little more backlash.
    Eric
    I wish it wouldn't crash.
    Sep 2003
    I’d like to expand the topic of this thread to include the use of two motors driving two screws.
    If one were to use two servos with 250 CPR encoders and Gecko drives with the step and direction lines tied together, how much of a misalignment drift might one see over the course of regular use?
    I’m planning my screws to be 64 inches apart and am only able to find “L 1in” endless belts up to 90” around. I would need at least a 146” belt to couple my screws to a single motor. (64”x2 + 3 Pullies and 2 Idlers) How does the rest of the world deal with this?
    Thanks,
    Tim T
    TT
    1. Linear Motion FAQ
      By Cutters Cove in forum DIY CNC Router Table Machines
      Last Post: 09-30-2009, 02:36 AM
    2. Where to purchase linear motion goodies
      By mxtras in forum Linear and Rotary Motion
      Last Post: 08-04-2005, 10:22 PM
    3. Linear motion
      By Wez in forum DIY CNC Router Table Machines
      Last Post: 12-07-2003, 01:54 AM
    4. Structural Debate: The Best Linear Motion Method
      By CNC Brute in forum DIY CNC Router Table Machines
      Last Post: 11-22-2003, 11:10 AM
    5. 8020 linear motion products
      By bb99 in forum DIY CNC Router Table Machines
      Last Post: 11-08-2003, 03:21 PM
