Results 1 to 11 of 11
Thread: Power Supply
    May 2006
    Power Supply
    I'm planning on using a few compuer PSUs connected together for my power. My steppers are 24V, would this work? Any suggestions on dirt cheap [read almost free] power supplies?
    Dec 2005
    1. Go here:
    http://www.cnczone.com/forums/showth...015#post142015
    http://forums.bit-tech.net/showthread.php?t=108208
    2. Follow the instructions
    3. Don't get creative.
    4. Safest method is to use MATCHED units (make, model, size).
    Mar 2003
    Shelby Twp, MI....USA
    Your going to need different steppers, rated 6V or less, preferably 2-3V. 24V steppers will spin very slowly.
    May 2006
    Quote Originally Posted by ger21
    Why, with a couple PSUs connected I can get 36V or more.
    Mar 2003
    You'd probably need over 100V to get any kind of performance at all. Ideally you want to use 10-20x the steppers rated voltage.
    Try them and see how it works.
    May 2006
    What kind of power supply do you recomend? I'm running on a shoe string budget here, figure my controller is going to cost me ~$30 to build, a sheet of 3/4 MDF is ~$20, and leadscrews at ~$10. That will leave me with ~ $10 left. My entire budget is from selling a calculator on Ebay. I am searching for some of my spare stuff around the house to ebay, have a small pile started already.
    Dec 2005
    Low cost P/S
    For a PS that will operate at 100vdc, you're pretty much relegated to a linear with an output somewheres in the vicinity of 70vac.
    Then again, with a $10 budget and 'almost free' computer p/s's available, all you'd have to do is score 8 matched @ 12 volts each should be close enough - don't forget to get a free terminal strip or two to plug them into....
    IF you do go the linear route, the following links (adjusted as needed for voltage and current of course) should handle the design aspect of the project:
    Linear P/S design/construction
    http://www.campbelldesigns.com/files...ply-part-1.pdf
    Servo amp P/S design
    http://www.elecdesign.com/Articles/A...7635/7635.html
    Servo motor, servo amp & powersupply sizing for CNC
    http://www.rutex.com/pdf/Mystique2.pdf
    As far as sourcing goes, start looking for/through surplus houses or machine salvage places or motor/transformer service shops. Old transformers from machines can be a life saver for a low budget operation but even so, a $10 budget will be excruciatingly TIGHT.
    BTW, Rutex has servo drives that will go 200v which should easily cover a 100 volt system. I would NOT use a drive rated at 80 or 90 volts to drive 100.
    Mar 2003
    Will the $30 controller your building handle 100V? You really should try to find some different motors.
    Jan 2005
    Missouri
    Try some of the bigger copy machine sellers. They usually take the old machines back with them and trash them. It is a good source of free parts.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    May 2006
    Got some cheap? I'm suprised these are rated at 24V, they came out of printers that had nothing over 12V in them. Although I do still have the PSUs out of the printers. Also possible is that I don't know how to read the data sheets on these, anyone willing to confirm for me? Here they are: http://www.eminebea.com/content/html...f/pm35s048.pdf 2 of these http://www.eminebea.com/content/html...f/pm55l048.pdf 2 of these [planned X and Y -axis] and http://www.mitsumi.co.jp/Catalog/com.../4/text01e.pdf 1 of these.
    May 2006
    Forgot to mention, the controller I'm planning on using is Phils [Pminmo] 3axis Self Contained board . It says it can handle motors up to 30V, so if I'm reading it correctly, it can handle it. If I'm wrong, someone correct me, and point me to a better controller.
  • Posting Permissions
