Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: CNC Glass Scoring Machine Anyone?
    LHC
    LHC is offline
    May 2006
    Hi folks -
    Joined the forum here a day or so ago and have not gotten much work done at my desk since
    Has anyone come across a version of these mdf cnc machines that have been set up for scoring glass? My fiance and I are into stained glass projects lately and I was thinking, that a gadget that would be able to score the lines from a pattern would be slick. The catch would be that the scoring head would have to remain tangential to the curve and although I see that the mach software supports this, I have not seen anyone that has come up with a motorized head to swivel the cutter.
    Anyway, if anyone knows where I might go to see some ideas/options, that would be great.
    Cheers,
    Lewis
    Nov 2004
    I saw some machines for cutting cardboard/foam/neoprene etc that use a tangential knife... keep the tangential part and substitute the scoring blade and your good to go
    LHC
    LHC is offline
    May 2006
    Quote Originally Posted by ShayArnett
    I've been searching for some home-brew versions like this but haven't come across anything yet. Another idea that I had was to use an air cylinder for the Z axis to raise/lower the cutter assy. That way, you can asjust the scoring pressure and also take care of different types of glass that have a non uniform surface. Blindly lowering the scoring cutter to a certain depth will not work.
    May 2005
    Just a thought, What about spring loading the cutter?
    Brian
    The Sawdust Creator
    Dec 2005
    Venezuela
    I all sow run a stained glass studio and would be really interested in learning more about these possibility.
    Thanks for any help.
    Hugo Carradini
    www.vitrales.com.ve
    LHC
    LHC is offline
    May 2006
    Quote Originally Posted by phillby
    I thought about that, and it would probably work but I think you'd need a way to "tweak" the tension of the spring to fine tune and the "down/up" movement might be a little abrupt - i.e. you don't want to have the cutter come crashing down too hard - after all - you are landing on glass
    The beauty of the air cylinder would be that you could easily adjust the pressure with a small regulator, as well as controlling the speed of decent/rise with a needle valve. The compressed air approach would be more cash than a spring, but I think it's far more "controllable". Not to mention the wow factor would be just huge with the "hissing" of the cylinder as the cutting head was moved up and down - haha
    Looks like we have a few more souls interested in this as well as myself - hopefully we can collectively come up with some ideas.
    Cheers,
    Lewis
    Jul 2005
    Some time ago I read somewhere.... I looked it up I couldn't take not remembering.
    Would something like this work with a glass cutting wheel?
    http://www.cuttingedgecnc.com/vinyl.htm
    Check out the blade holder take 5
    Stephen
    May 2003
    UK
    I like the air cylinder idea, you could make it two stage, apply low pressure for tool down, apply higher pressure for scoring force. Use high pressure for retract.
    I saw some automated glass cutting on "how its made", the machine pulled a diamond scribe across the glass and then went around with a little blowtorch, the thermal shock finished the cut. Very nice!
    It shouldn't be too difficult to make a spring loaded or air loaded scoring tool. I'm sure you could even make a CNC blow torch if you wanted.
    Graham
    Registered greybeard's Avatar
    Jun 2005
    UK
    The diamond point glass cutter that I use for manual cutting is pivoted, with the point about 1mm trailing the pivot. I would think that the accuracy of this would be more than sufficient for it to be used to score the patterns without any mods.
    Mind you, I've not cut a rough surfaced glass. Are both sides uneven ?
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
    LHC
    LHC is offline
    May 2006
    The most common cutters (at least around here) that I have seen are carbide wheels in a little metal holder that pivots about 30 degrees each way in the end of the handle (barrel). The metal pivot and wheel can be separated from the cutter handle and re-mounted into a custom machined mount on a CNC machine easy enough, but using it like a drag knife and not a true tangential axis controlled cutter is something that I am not sure if it will work or not. If it did, it would certainly simplify the mechanism. Might have to tinker a bit and test it.
    The two stage force and blowtorch ideas are excellent ones. I never tried thermally shocking the glass to separate it, and as soon as I get home tonight I'm going to be digging out the propane torch and some scrap glass to try that out.
    The unevenness of the glass is not that severe - and there is usually one side that is a "smooth" side per se to cut. But it is "wavy" on some types of glass - hence the need for some "springy" force to apply the cutting wheel onto the glass and follow the hills and valleys. If I had to guess I would say that worst case would be 0.025-0.035" unevenness - at least on the type of glass that I have used.
    The more I think about this project the keener I am getting - guess I'm no different than all of you fellows !!
    Registered buscht's Avatar
    Nov 2003
    I've been thinking about a different approach for stained glass.
    I think Gryphon makes a glass cutting bandsaw. I would like to put a X-Y CNC table on the front and simply move the glass around the blade. The advantages would be that intricate shapes would be easy to do.
    I've never used this bandsaw so I don't know if it would work, but I've hooked this setup to my scrollsaw and it works pretty good.
    Trent
    LHC
    LHC is offline
    May 2006
    Quote Originally Posted by buscht
    Trent
    Interesting idea. I have not used a glass saw but have seen them in action. I am thinking they might be painfully slow - even for the hobbiest. The instructor was using one at the place my fiance and I took our begineer class at, and while it looked slick and would make cuts that could never be done by scoring, it did seem very slow.
    I was going to try the blow torch / thermal shock technique at the house last night when I got home as a technique to separate already scored glass, but could not find the torch! Might have to go buy one today just to see if it works on the art glass that we use.
    Have you got any pics of your scroll saw cnc set-up? I'd be interested to see it.
    Cheers,
    Lewis
  • Page 1 of 2 12 LastLast
