Results 1 to 3 of 3
Thread: Urethane Resin Casting: Linear Glides & Leadscrew Nuts
    Feb 2006
    Well I’m going to step WAY outside the box and
    try something completely different (as far as I know).
    Take a look at my post in the VBGarage for details
    http://www.cnczone.com/forums/vbgara...=view&id=25767
    The Resin I'm using comes from Alumilite Corp.
    http://www.alumilite.com
    Attached Thumbnails Attached Thumbnails Urethane Resin Casting: Linear Glides & Leadscrew Nuts-sliding_table-1_.jpg
    Mike_L
    When I was younger I thought I knew EVERYTHING,
    NOW, the older I get the more I find out I don’t know!
    May 2003
    Illinois
    Sliding bearings
    Sir,
    Are you aware of the bearing products made by Pacific Bearing Company? These are "Rulon" or some similar tradename, and are available in LOTS of sizes and mounting variations.
    www.pacific-bearing.com
    Regards,
    Jack C.
    Mar 2004
    Iowa, USA
    I looked at their products. Pretty good. Did you see the Square Bearing under the Simplicity heading? Neat concept.
    RipperSoftware
