http://www.hurricanecues.com/db2/001...heet-3copy.jpg
My father makes Hurricane Cues, he is semi-retired but still turns a few sticks here an there. He uses 2 cnc routers running .020 carbide cutters. One is standard 3 axis for cutting inlays other is 4 axis with rotary device for the pockets. He runs them with a Foredom motor and some little high speed spindle. He also turns the Hurricane symbol in stainless steel which is a very tender setup.
Hague
LinkBack URL
About LinkBacks
I am not sure but I thin these guys make their own inlay material and is probably thicker that what we might think. I am curious if they make it thick enough to do the pocket without ever rotating the stick, insert the inlay and then surface off the excess!
