Results 1 to 6 of 6
Thread: What Spoil board cutters to use and best place to buy
    Dec 2011
    Hi everyone,
    Just recieved from a friend a 1.2 x 1.2 acrylic board i was going to use as a spoilboard. What is the smoothest/best finish cutter you recommend to use on acrylic.
    It would also be great if same cutter had the same results on MDF spoilboards. Found these mini cutters http://www.toolstoday.com/p-6160-min...-2-design.aspx
    Thanks in advance.
    Mar 2003
    Shelby Twp, MI....USA
    Your typical spoilboard cutter probably won't work very well with acrylic. You'll most likely get a lot of melting.
    I think for acrylic, your best bet would be a 1/2" upcut spiral, probably a single flute "O" flute.
    The tool you linked to will be great for MDF, though.IF you want something cheaper, just find a large 2 flute straight bit, or something like this.
    http://www.amazon.com/Magnate-Surface-Planning-Bottom-Cleaning/dp/B0006B0QXO/ref=sr_1_1?s=power-hand-tools&ie=UTF8&qid=1335699447&sr=1-1]Amazon.com: Magnate 2707 Surface Planning ( Bottom Cleaning ) Router Bits - 2-3/4" Cutting Diameter: Power & Hand Tools
    Dec 2011
    Thanks Gerry. At the end of the day if the cutter from amazon in link does the same job as the more expensive one in my link, it means i can spend the extra money on buying a upcut spiral for use on acrylic.
    The price of end mills and spoilboard cutters by some is outrageous.
    Have you used the surface planning bit from amazon and did you get good results?
    Mar 2003
    No, I haven't tried it.
    Apr 2009
    Looking at the Amazon bit, not sure how well it would perform on acrylic... The center of the bit could be a problem. I'd check out a 1-1/4" door hinge mortising bit. Wide enough, but non-center cutting which should get riid of chips easier. You'd have to ramp in however....
    Have used single edge spiral-'o'-flute bits on acrylic with success (as well as other plastics and wood...)
    Registered Enk1du's Avatar
    Jan 2012
    Is there a concern for warping when you are using a plastic like acrylic as a spoilboard? With a piece as thick as the one you're planning to use I'd assume its cast and not extruded, but isn't there still a chance that there are non-uniform stresses across the thickness of the sheet?
    Personally, my experience with machining acrylic has almost always been negative, so I may be biased.
    edit: from the amazon link above, I saw http://www.amazon.com/Roman-Carbide-DC1261-2-Inch-Cleaning/dp/B005W18EIW/ref=pd_sim_sbs_hi_2]this other bit. If 1.5" is enough, its 1/4 the price of the 2.75" one.
    1. Need Help!- Spoil board cutter?
      By mafitch7479 in forum Commercial CNC Wood Routers
      Last Post: 08-23-2011, 11:37 PM
    2. Surfacing the spoil board
      By Rickv100 in forum JGRO Router Table Design
      Last Post: 10-31-2009, 03:28 PM
    3. Need Help!- What is the purpose of a spoil board?
      By j_wizard in forum CNC Machining Centers
      Last Post: 10-27-2009, 10:18 PM
    4. Newbie- Spoil Board
      By lfourtner in forum JGRO Router Table Design
      Last Post: 12-15-2008, 01:40 PM
    5. Resurfacing spoil board
      By avccrml in forum WoodWorking
      Last Post: 08-12-2007, 09:01 AM
