search ebay for straight shank er20 collet chuck or whatever collet size you want to hold.
if you are interested in atc, search for bt30. you would need a spindle that has the taper to match. I'm not sure if there are ones available with a straight shank to fit inside bearings, which have the taper to accept the holder. If someone were to figure that all out, that would be wonderful.
LinkBack URL
About LinkBacks
