Results 1 to 9 of 9
Thread: Machining Delrin
    Aug 2011
    UK
    Machining Delrin
    I want to make some bearing blocks and a leadscrew nut
    I've bought a block of delrin, but just thought I check to see what the recommended feeds speeds depths and bits to use
    before I go experimenting
    Rich
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Nov 2007
    I've never cut delrin but I've cut high quality HDPE. As others have stated it cuts like buter.
    Using a 0.25" 2 flute upward spiral bit at ~10000rpm I cut at 50ipm taking 0.125" per pass with excellent results. I'm sure I can cut faster.
    Wouldn't HDPE be a more suitable material to cut bearing blocks with? About 1/4 of the price of delrin with good tensile strength. Easily can handle the work of bring a bearing block even in lower grades.
    Aug 2011
    UK
    Quote Originally Posted by jckstrthmghty View Post
    I already got me a block of Delrin to play with, It seems to be the material of choice for machining type things. I will see what else I can use it for too !
    Rich
    Gold Member
    Oct 2005
    A little video I made years ago machining black delrin.
    http://www.youtube.com/watch?v=Uh4JzgDrykg]CNC machining delrin - YouTube
    Registered kinghong1970's Avatar
    Apr 2009
    Quote Originally Posted by meadow View Post
    To see a world in a granda of stand.And a heaven in a wild flower.Hold infinity in the palm your hand and eternity in an hour.Cheap WOW Gold or Buy RS Gold and Diablo 3 Items
    why is this dude selling wow gold in a cnc forum?
    [SIZE="1"]my first..."[B][COLOR="Red"]Big Ape[/COLOR][/B]" CNCRP 2448 [URL="http://www.cnczone.com/forums/cnc_wood_router_project_log/151447-big_apes_crp-2448_build.html"]Build Log[/URL][/SIZE]
    Registered bobsch's Avatar
    Oct 2008
    Quote Originally Posted by kinghong1970 View Post
    I think it's called spam, and I don't mean the product from Hormel.
    Bob
    "Bad decisions make good stories."
    Aug 2011
    CA
    let us know how good it smells and what it smells like during and after milling.
    Registered ynnek's Avatar
    Apr 2008
    delrin does stink a bit as it is being machined. It contains formaldehyde. But it machines like a dream.
    1. Delrin Blank machining RFQ
      By zcases in forum RFQ (Request for Quote)
      Last Post: 11-25-2011, 01:25 AM
    2. Machining Acetal/Delrin guides
      By PMOrthotics in forum Glass, Plastic and Stone
      Last Post: 03-05-2011, 09:09 PM
    3. Help With Machining Delrin
      By sparkymeller in forum General Metalwork Discussion
      Last Post: 09-09-2009, 01:52 AM
    4. Need A Quote- RFQ Small delrin part suitable for cnc machining
      By rodjava in forum Employment Opportunity
      Last Post: 07-25-2009, 05:27 AM
    5. Problem- Machining Delrin
      By KonradyTom in forum General Material Machining Solutions
      Last Post: 12-24-2008, 12:15 PM
