Results 1 to 9 of 9
Thread: Need Help from the pros!
    Apr 2012
    Exclamation Need Help from the pros!
    Hey Guys.
    Im very new to the CNC Routers and just bought a Warthog CNC router and am having some issues.
    I saw it run when i bought it, everything was perfect, stored it in my garage for a month while i finished my shop, just moved it in and cant seem to get it working right.
    I just plugged everything into the computer and can only get the machine to move right and back. The Z axis wont work at all. I was on the phone with the tech all day and went over the whole wiring schematics, undid every wire and re put them in to make sure nothing got tugged out during transport and am still at square 1.
    When i try to go left or forward or use the Z axis, i can hear the motor making noise but it does not move. Someone PLEASE tell me im missing something obvious!!
    -Matt
    Oct 2004
    Are you using the same computer that was used when you saw it run? It sounds like you're not getting a proper high or low voltage on the direction pin of the driver.
    Chris
    May 2004
    Or...have you ever bought a box of 4 light bulb and took them home and mysteriously one of them does not work? Sometime electrical devices don't work due to poor craftsmanship and quality and no fault of your (except you bought it).
    http://www.kirkcon.com/
    Registered fizzissist's Avatar
    Apr 2006
    Shoulda bought a router from Jinan-The Beautiful City.
    When something goes wrong, they'll send you a picture of the warranty.
    May 2004
    Quote Originally Posted by xmxiufeng View Post
    hi guys, are you looking for cnc machining services from China? we can be of help if you like to.
    Look! There is one now!
    Apr 2009
    Did you try swapping the axis cables for x and y to see if you get the same problem?
    Apr 2012
    Yes, i swapped the cabels and had the same issue.
    The machine ran great before we moved it, but the software is over 10 years old and on a very old computer.
    After talking to the warthog tech, and the wincnc software people we ordered new software and are hoping that the computer got messed up during moving becuase of how old it was.
    Has anybody had this type of problem due to software being too old or moving the machine?
    Apr 2010
    The PC does not sound like the problem with the details given. It sounds more like a setup or config issue. Is there any chance that you lost or did not load the correct profile? What kind of breakout board / drivers are you using? It might be easy to hook up a different PC to it, and running a trial version of Mach3 try to create a new config for it from scratch. This will eliminate one half of your possible problems. If Mach3 works, then you know it's the computer software. If not, then you can suspect a driver and electronics issue.
    Plus it might be beneficial for you to upgrade to Mach3 anyways. Most folks here use that, and love it.
    Feb 2007
    Does your controller use a parallel port cable?
    Are you using the one that was originally with the machine?
    A printer cable that has some wires crossed might do this.
    1. Newbie- Looking to the pros for advice
      By rbmedic75 in forum General Waterjet
      Last Post: 08-11-2009, 10:31 PM
    2. Needing some help from the pros
      By Darkstar64 in forum DIY CNC Router Table Machines
      Last Post: 04-17-2008, 04:04 PM
    3. A little help from the Pros
      By robinsoncr in forum Rhino 3D
      Last Post: 06-15-2006, 01:58 PM
    4. Ask The Pros
      By ClockMaster in forum Stepper Motors and Drives
      Last Post: 08-12-2005, 03:33 PM
    5. What are the pros and cons of
      By CNCadmin in forum CNC Machining Centers
      Last Post: 05-19-2003, 01:31 AM
