Results 1 to 3 of 3
Thread: Bosch 1617 Feeds+Speeds table
    Jan 2010
    I pulled some numbers off of the Vortex chipload chart (http://www.vortextool.com/images/chipLoadChart.pdf) and my router manual for my feed+speed chart. As it took me a good hour, maybe someone else will find these useful too.
    (PS. I guarantee nothing, the 3/16 numbers I approximated, and use at your own risk. PDF is 8.5x14", use the Excel if you want something different. Numbers generated by Google.)
    Vestus
    Attached Files Attached Files
    Jun 2010
    thanks for the post. iam working on my machine now and was wondering feed rate. currently i can only get 50 ipm. with the lead screws.
    Jan 2010
    Single flute bits can get you closer to optimum speeds. Cutting with a high rpm just wears out bits because they heat up too much.
  1. Feeds & Speeds
    By weihmue in forum General Metalwork Discussion
    Last Post: 02-05-2012, 08:56 PM
  2. Controlling Speed of Bosch 1617 via CNC
    By n1k86 in forum DIY CNC Router Table Machines
    Last Post: 07-15-2011, 06:02 PM
  3. Need Help!- speeds and feeds
    By ponchosb77 in forum CNC Tooling
    Last Post: 02-25-2011, 05:12 PM
  4. Need some help with speeds & feeds
    By ldkell_2000 in forum General Metalwork Discussion
    Last Post: 03-01-2008, 11:35 AM
  5. Need Help!- speeds and feeds
    By rodzilla in forum Benchtop Machines
    Last Post: 02-19-2008, 11:30 PM
