Results 1 to 8 of 8
Thread: Home switch setup (pulling my hair out)
    Registered Dahlberg's Avatar
    Jan 2010
    Denmark
    Hello everyone. I am trying to setup homing switches on my mill, but mach3 gets no signal. I have a Damen cnc BOB and have wired the y axis wire to port 1 pin 4 and 3 on the BOB. It triggers the signal on the BOB but Mach3 does not read it. What am I doing wrong!!!!!!
    Attached Thumbnails Attached Thumbnails Home switch setup (pulling my hair out)-bob.jpg
    Registered doorknob's Avatar
    Jan 2010
    Can you provide some more information?
    Are you using a normally-closed mechanical switch, or an inductive proximity sensor, or an optical or hall-effect switch, or something else?
    Are you trying to use port 1 pins 3 and 4 as inputs? You should be able to use only a single input for a home or limit switch. Do the BOB terminal numbers correspond to the LPT port pin numbers? If not, what is the mapping between BOB terminal numbers and LPT port pin numbers?
    If you are using a mechanical switch, do you have a pull-up resistor wired to the NC switch contact and +5 volts?
    Registered farmertom's Avatar
    Dec 2010
    Quote Originally Posted by Dahlberg View Post
    Make sure that you have all of your settings correct in Mach3. config => ports and pins => input signals. Make sure that the port number is not 0. It should be a 1 if you have one printer port. Also on bottom of that page is an Auto setup for input pin detection. It helped me out!
    hope this helps
    farmertom
    http://cncartwork.weebly.com/index.html
    Jan 2010
    Denmark
    I just realized that the lpt cable I used, only had 9 leaders in it, so I will try another one, this will proberbly work. I will post as soon as I have tried.
    Jan 2010
    Denmark
    Just as I thought, it was the lpt cable, so now the switches work. now I have another problem, witch is: when I home the Y axis it triggers the switch and go back untill the switch closes again (N/C switches), but when I tries to home the Z axis it triggers the switch and then stops and errors. What am I doing wrong???
    Jan 2010
    Have you tried swapping out the switch? I had something similar on mine, and I think my switch was bouncy or on the way out.
    My theory was that it triggered and opened the switch, backed up enough to close it long enough to trigger Mach, stopped the movement, and then it bounced open, triggering the fault.
    Jan 2010
    Denmark
    My home switches is working now, thanks for your help everyone
    Mar 2011
    Increase the debounce setting if you keep having problems.
    My CRP 48 x 48 build [URL="http://www.cnczone.com/forums/open_source_cnc_machine_designs/144173-crp_4x4.html"] CRP 4x4[/URL]
    1. Need Help!- FLA-200 Linear Bearings Pulling my hair out!
      By crash5050 in forum Open Source CNC Machine Designs
      Last Post: 05-07-2011, 12:31 AM
    2. Need Help!- Pulling hair out! Problem with material webbing.
      By xncrman in forum Vacuum forming, Thermoforming Etc
      Last Post: 01-29-2011, 10:58 AM
    3. pulling hair out
      By radioman in forum DIY CNC Router Table Machines
      Last Post: 01-05-2010, 04:16 PM
    4. Need Help!- HAAS MINI MILL Question (I'm pulling my hair out)
      By Powder_Keg in forum Haas Mills
      Last Post: 09-19-2008, 10:09 AM
    5. 203V Pulling my hair out!!
      By WilliamD in forum Gecko Drives
      Last Post: 04-18-2008, 02:09 AM
