I believe this is the more common method. The disadvantage can be (depending on pulley size and belt type) that belt backlash, elasticity, long term stretch and thermal effects can affect the positioning accuracy of the x-axis. I did not like that.
I rather invested in two dual shaft steppers and 2 drives and coupled them with the single belt for safety. I do not "slave" the 2nd motor in the
CNC controller but run both drives parallel on the same controller pulse output. Given same size motors, it gives me also more oomph to swing the heavy gantry around than a single motor.
