Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: CNC-routerbuild-advise
    Apr 2012
    Sweden
    Hi!
    Im a mechanical engineering student i Sweden, working on a school project of building a cnc-router. The goal is that it should be able to cut aluminum as the hardest material.
    I have no idea of what the budget are and I am only in charge of the construction and motors.
    I quote teacher:
    "At this point I tend to say that I'm not interested in something special because I won t use it as a high volume production machine. So my philosophy is that the machine need enough power to cut "metals"...and at the same time I want to keep the cost down as much as possible...meaning small motors, linear guides ball screw etc"
    I am supposed to use aluminum profile that exist in the school.
    In my working design i have used 40x40 and 40x80mm profiles.
    The ball-screws are not yet calculated, just sits there to see how it will be assembled. Im thinking about moving the table in the x direction and the spindle moves in the y and z axis.
    All screws and stuff like that is not yet put in the cad model.
    Dimension so far so you can see the size of it.
    High: 500mm
    Width of gantry: 780mm
    Length: 1500mm
    Z-axis back support plate: 300mm
    Still looking at some different kind o linear guidelines due to those that are in the picture is kind of expensive, yet they are the most powerful as far as i know.
    My concern is if the construction is stiff enough to be able to cut aluminum?
    Have powerful bearing you need to hold for the cutting force? Would be nice to not over size them if not needed.
    The work range should be at least 650x450x150mm.
    Cuttingspeed (?) around 100m/min and optimal for aluminum cutting.
    I got no experience in building a cnc-router.
    I am interested in your thoughts and ideas as it appears you guys posses a lot of knowledge in this subject.
    Anything I have missed and need to rethink?
    Note: The design and redering pictures is made in Pro engineer.
    Enjoy!
    Attached Thumbnails Attached Thumbnails CNC-routerbuild-advise-cnc_bild-3.jpg   CNC-routerbuild-advise-cnc_bild_1.jpg
    Oct 2004
    Looking at your drawing the gantry seems too tall for the spacing of the bearings that ride on the X rails. You may also have issues with rigidity of the gantry in the Y direction.
    Chris
    Apr 2012
    Sweden
    Quote Originally Posted by OCNC View Post
    Chris
    The distance to the table is not yet adjusted. Maby have to shorten the profiles on the sides.
    Any suggestion to improve the rigidity?
    Nov 2011
    Quote Originally Posted by r1kkie View Post
    I think the profile used on the base is a little wimpy, the rails mounted to them would provide more rigidity. Either that or I'm just used to overkill.
    Apr 2009
    I'd agree that you might want to stiffen the base up some. Possibly bolt it down to something heavy? As it sits, it looks like the gantry would cause the base rails to flex under load...
    Oct 2006
    I 'advise' you to learn how to spell 'advice'. Sorry, couldnt resist!
    Apr 2009
    Quote Originally Posted by mgman71 View Post
    Advise is the correct word, as in a verb. Advice is a noun, and in the context of the title the word "advice" would imply that it lies within the thread. But in this context, the OP is asking for advice; he wants us to "advise" him of what is needed. Or another way to look at it: You can make a one word sentence with a verb, but not a noun.
    So I guess I'd have to "advise" you to take the context into consideration as well...
    Aug 2006
    I would check out cncrouterparts.com.
    I just put together a machine for a client using their parts and it was effortless. Searching for a lower cost linear rail drove me to their site originally.
    The best part is he released all of the 3D models of the parts which makes designing your machine a breeze. A ballsey move but his prices are so good that even though I have the capacity to CNC machine the parts it just wasn't even close.
    Not affiliated blah blah blah disclaimer your milage may vary or may be lost in translation etc....
    Derek
    Feb 2012
    England
    Why is a milling machine made of steel as opposed to aluminium.
    Apr 2012
    Sweden
    Quote Originally Posted by HorridHenry View Post
    As far as I know the frams are made of cast iron witch is a great material to withstand vibrations.
    Correct me if Im wrong...
    Apr 2012
    Sweden
    Quote Originally Posted by flojor10 View Post
    I see what you mean. Havent paid much attention to it so far. Kind of building up to down.
    Made som changes to the bottom to increas the rigidity, my be some more change. Will be kind of hard to get the screw under it as its designed now.
    Apr 2012
    Sweden
    Here is the latest model...
    My concerns right now is if the gantry is rigde enough to the base porfile? what do you guys think? maby put some cross beams across on it, see picture below...
    Attached Thumbnails Attached Thumbnails CNC-routerbuild-advise-bild_4.jpg   CNC-routerbuild-advise-bild_5.jpg
  • Page 1 of 2 12 LastLast
    1. Need advise
      By Scuba Steve in forum General Metal Working Machines
      Last Post: 12-03-2011, 09:00 PM
    2. a little advise
      By DistortedDesign in forum Joes CNC Model 2006
      Last Post: 05-29-2010, 03:10 PM
    3. looking for advise
      By phill05 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-09-2010, 03:19 AM
    4. need some advise
      By joey1117 in forum Benchtop Machines
      Last Post: 09-01-2007, 10:47 PM
    5. Will this get me going? Please advise...
      By Witsenburg in forum Stepper Motors and Drives
      Last Post: 04-13-2007, 11:50 AM
