Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: My order with linearmotionbearings2008 (good experience)
    Feb 2007
    HI All,
    Today I received my order from linearmotionbearings2008. It took 8 bus days from the time I paid him.
    Thought I'd share in case everyone is wondering about the quality and service..
    I got:
    2 1250mm, 2 800mm, 2 400mm rails with 4 bearings each.
    2 1300mm, 2 850mm, 2 450mm ballscrews with nuts
    3 bk12 bearings
    3 bf12 bearings
    3 flex couplers
    Here's some pics and a little causualties....
    You'll notice that the rails don't have mounting holes??? Maybe it's better that way since you can now drill the holes so they'll fit SAE extrusions....Normally they are 30mm apart. I also have issues getting the bearing blocks on the ballscrews...it's tight, but I think I can fix that with some 600 grit sandpaper..
    Also those measurments are approx values...although the ends are 10mm and 12mm in diameter.
    I think the quality is pretty good considering....
    newpatch
    Registered Walky's Avatar
    Jul 2009
    Chile
    I got a package quite similar to yours a couple of days ago (it must be my 7th or 8th purchase from Chai so far).
    My rails are also not drilled (this is the first time they come like this). I actually like it, and the reason for me not asking for it before was the fear of a misunderstanding resulting in me getting "blank" rails too (I don't have the proper equipment to drill and tap such rails). The rails supports and blocks are a little damaged (only the aluminum parts), but not much. I noticed that this time my 16mm blocks came with two set screws (top and side), while a set I got a couple of years ago only had one on top.
    Ballscrew machining is amazingly smooth as always, and apparently according to specs.
    I bought 14 blocks this time instead of 12 (I want to use 3 on each gantry side to help reduce racking), but I got 12, I think it is an understandable mistake considering that's what must people buy. I notified Chai, he apologized and the next night I had the tracking number for the missing blocks at my inbox, nice!
    It's pretty common for the screw's machining to be a tight fit on the blocks, I use some wet sandpaper and they work great afterwards (maybe they can just be pressed in with the proper equipment, without sanding). I'm perfectly fine with oversized diameters, since undersized diameters would be a PITA to fix.
    Some BK blocks can have internal play sometimes, it can be easily fixed by adding a couple of shims to create preload. I usually disassemble the blocks to check that the bearings at actually back to back, add some grease and shims if necessary.
    IMHO, it's really great stuff considering the cost. Not perfect, but I'm willing to spend a few hours or days tuning things up if that means not having to pay way more than twice for the "real" thing. I'd love to see picture's of the facilities where they do the machining of the ballscrews.
    BTW, if you need wider hole separation you can ask Chai for TBR rails (similar to SBR, but the support's base is wider).
    This is what I got:
    Aug 2011
    Quote Originally Posted by newpatch View Post
    I had the same issue, 600grt wet/dry paper. Cut a piece about 1" x 3" (didn't want to mar the threads), wrapped it around the section that was tight and twisted the screw by hand for about 20mins, cleaning it off then checking fit then repeat (while I watched tv of course). Once I got the screw buffed down so the bearing would slide on I had another issue. The locknut binding on the rubber seal. Lou suggested a socket that's the size of the seal and press it in further which helped a lot (at the time I didn't realize they can be pressed). I hadn't used my cheapo arbor press in ages, it was about time it earned its keep.
    And I agree (not that mine has seen a nano-second of use) they seem great for the price and the wait isn't long at all even for custom sizes.
    Registered port_huon's Avatar
    Dec 2007
    It's good to see that his quality hasn't declined with popularity. I first bought some ballscrews from him about 4 years ago.
    I wish he'd stock flangeless ball nuts though.
    Regards
    Geoff
    Feb 2007
    My bearing blocks also have 2 set screws....
    Hey sixofone.....that locknut your talking about that goes on the ballscrew do your have set screws on the corners??? Mine do but if you look on the inside the hole the set screws are not drilled all the way through??? Is it supposed to be?
    "Ballscrew machining is amazingly smooth as always, and apparently according to specs."
    I agree Walky...yesterday I held the ballnut on one of my ballscrews, and the ballscrew started twisting off by itself very smotth...my other ones need some minor cleaning to get the film off....
    Also, since I won't use this parts for a while, what oil do I use on the rails, ballscrews, etc., so that they won't rust or pit??? I read somewhere here someone used air tool oil?? I have plenty of it...
    newpatch
    Feb 2012
    England
    Is this new stuff or discount?
    can't say I would be happy with some of the components you have there.
    Jul 2009
    Chile
    If you check the internal thread, you'll notice the thread directly under the set screws is a different color/material, that's because the set screw will actually press those thread sections against the screw (this prevent damaging the screw's thread). I guess (haven't confirmed it, though) that those pieces of thread might fall off if you turn the setscrews without the nut being installed, so I'd be careful not to do that.
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by HorridHenry View Post
    New, direct from China. here in the US, you can buy the same chinese parts from a reseller for 50-100% more. Or buy higher quality for 5x more?
    You can't have your cake and eat it too.
    Jun 2011
    Malaysia
    Quote Originally Posted by ger21 View Post
    sorry to say... but I'm thinking, higher quality product actually not from US made...
    Feb 2012
    England
    According to their feedback....damage is a constant thing....dang! I wouldn't worry about the damage I'd be more worried about the poor quality of the material.
    Feb 2012
    England
    pmsl
    Mar 2012
    Thanks for all of that information and pictures!
  • Page 1 of 2 12 LastLast
    1. Need Help!- Ballscrews for G0704 Clone from linearmotionbearings2008 ?
      By jdurkin in forum Benchtop Machines
      Last Post: 01-05-2012, 07:09 PM
    2. Newbie- Cut order?
      By JAnimis in forum BobCad-Cam
      Last Post: 06-15-2011, 05:26 PM
    3. New IH on order...
      By ksanalytical in forum Industrial Hobbies (Support forum)
      Last Post: 10-02-2010, 11:43 PM
    4. Items from ebay linearmotionbearings2008
      By ghassall in forum DIY CNC Router Table Machines
      Last Post: 01-17-2010, 07:29 AM
    5. New VF-5 on order
      By rbest27 in forum Haas Mills
      Last Post: 12-16-2007, 12:43 PM
