Page 1 of 3 123 LastLast
Results 1 to 12 of 34
Thread: my cnc build...
    Jun 2011
    my cnc build...
    I'm a tool maker by trade and I own my own bridgeport here at home.
    When I seen others making machines it got my wheels turning and I've wanted one for a couple years now and I just can't see purchasing a manufactured machine because they simply want to much for them.. I think the kits are way overpriced also..
    I started building my machine a couple months ago, working on it little by little. I come up with a design in my head, and started building it with materials I mostly had on hand, and a friend also donated the extrusion and odds and ends, this saved me a great deal of money.. The extrusion was sourced from an old modular office that was purchased at a salvage auction for $40.
    My goal was to build my machine for under $800. I've went over it a little, but it was because I decided to build it a little better than initially planned after i got into it.. I will have right at $1000 in it when I'm done.. but no big deal that I went over the budget.. I havent had as much fun building something in a long time.. Its been interesting, the thought process and designing aspect has been interesting and the forethought not to design yourself into a corner makes it more fun....
    I think I have come up with a good inexpensive design, The electronics might fall short because I'm using the cheap tb6560 board but initial testing on my Y axis I had the steppers tuned at 900ipm and they were working, I know it wont be that fast when I get everything else hanging on the gantry, but it also leaves room to upgrade..
    I'll add pictures randomly though out the build up to the point I am at now so you guys get the idea I'm going with..
    Jun 2011
    some pics
    extrusion frame milled to length and bolted together..
    using the extrusion frame as a fixture to make the steel frame..
    frame clamped up and welded, some tig welded and some mig welded..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00454-20110916-2024.jpg   my cnc build...-img00455-20110921-2202.jpg   my cnc build...-img00456-20110926-2009.jpg   my cnc build...-img00457-20110926-2009.jpg
    my cnc build...-img00462-20111014-1209.jpg   my cnc build...-img00463-20111014-1209.jpg
    Jun 2011
    a few more pics..
    adding casters and leveling feet... leveling feet are carriage bolts with the heads faced flat.. I will probably add some nice leveling pads later on..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00464-20111014-1209.jpg   my cnc build...-img00466-20111014-1305.jpg   my cnc build...-img00468-20111014-1306.jpg   my cnc build...-img00472-20111015-1735.jpg
    Jun 2011
    here is what i come up with the rails and skates.. I havent seen a design like this yet so I figured I would share it... This is the cheapest way I could figure out for the rails... I used 1x2x1/4" angle.. I milled the 1" side of the angle down to .900 to leave stock, and also get a flat top surface for the bearing to ride on.. I used an extra piece of extrusion as a jig and used my bridgeport to mill the angle..
    I was surprised how well they turned out... I used rollpins to locate the rails on the extrusion, button head bolts to bolt the rails down.. The extrusion is 80x40 and 40x40 extrusion..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00476-20111029-1727.jpg   my cnc build...-img00477-20111029-1727.jpg   my cnc build...-img00483-20111104-1923.jpg   my cnc build...-img00484-20111104-1923.jpg
    my cnc build...-img00486-20111105-1822.jpg   my cnc build...-img00487-20111105-1822.jpg
    Jun 2011
    getting to the skates now... The rails machined out closer than what I figured they would.. after I milled the tops they mic'ed within .005.. I'm going to try to leave them like they are, I just cleaned the scale off of them and using them like they are.. If I need to I can break the sides off and put them in the mill and mill the sides of the rails to get them closer, I dont think I'll have to though, I think they'll wear in better actually..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00523-20111231-1653.jpg   my cnc build...-img00524-20111231-1653.jpg   my cnc build...-img00525-20111231-1653.jpg   my cnc build...-img00526-20111231-1653.jpg
    my cnc build...-img00527-20111231-1654.jpg   my cnc build...-img00530-20111231-1655.jpg
    Jun 2011
    more of the skates
    Attached Thumbnails Attached Thumbnails my cnc build...-img00531-20120101-1927.jpg   my cnc build...-img00532-20120101-1927.jpg   my cnc build...-img00537-20120107-1647.jpg   my cnc build...-img00538-20120107-1647.jpg
    my cnc build...-img00540-20120107-1648.jpg   my cnc build...-img00541-20120107-1648.jpg
    Jun 2011
    yet more of the skates.
    Attached Thumbnails Attached Thumbnails my cnc build...-img00547-20120110-2002.jpg   my cnc build...-img00548-20120110-2002.jpg
    Jun 2011
    next is bearing blocks and 4:1 belt drive reduction.. bearings were sourced from vxb..
    bearings are press fit in the blocks..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00559-20120122-1252.jpg   my cnc build...-img00561-20120126-1702.jpg   my cnc build...-img00558-20120122-1251.jpg   my cnc build...-img00575-20120222-1601.jpg
    Jun 2011
    these next pictures are of the gantry side plates, gear reduction mounted, skates adjusted, gantry squared up..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00583-20120226-2053.jpg   my cnc build...-img00584-20120226-2159.jpg   my cnc build...-img00585-20120226-2159.jpg   my cnc build...-img00588-20120227-1802.jpg
    Jun 2011
    these pictures are of the gantry top plates, and I think I have a picture that show the top straps that secure the gantry beam to the side plates.
    Attached Thumbnails Attached Thumbnails my cnc build...-img00592-20120229-1609.jpg   my cnc build...-img00593-20120229-1628.jpg   my cnc build...-img00595-20120229-1629.jpg
    Jun 2011
    arm for computer, monitor,keyboard.
    Attached Thumbnails Attached Thumbnails my cnc build...-img00613-20120331-0218.jpg   my cnc build...-img00615-20120331-0218.jpg
    Jun 2011
    enclosure and electronics mounted up.. added exhaust fan, a filter panel on the bottom, also an outlet... took the stock fan off and replced with 2 12vdc fans, also running the exhaust fan and driver fans off of a transformer instead of the board itself..
    Attached Thumbnails Attached Thumbnails my cnc build...-img00564-20120211-1850.jpg   my cnc build...-img00565-20120211-1850.jpg   my cnc build...-img00567-20120214-1809.jpg   my cnc build...-img00568-20120214-1809.jpg
  • Page 1 of 3 123 LastLast
    1. Replies: 3
      Last Post: 01-04-2013, 11:24 PM
    2. Mint's Build Aluminum/Steel Build thread.
      By FreshMint in forum Maintenance DIY Discussion
      Last Post: 10-30-2011, 11:18 PM
    3. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    4. New Large Table Build in Houston, TX (Build Log)
      By anitel in forum Plasma, EDM and other similar machine Project Log
      Last Post: 12-30-2008, 03:45 AM
