Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Top dumb things you've done on your CNC
    Apr 2009
    I can go on and on, but here are a few:
    1 - I drilled some holes to hold some parts down with screws. After fastening the screws, I mistakenly didn't deselect the drill op in the second program. I actually milled off one screw head, but by the second one the bit was ruined.
    2 - When I first started using OneCNC, I didn't know how to configure the post-processor. For some reason the park Z was at 300 (probably because it's set up in metric initially). I heard my stepper stall for a few seconds, then my Z came crashing down into the table, burning a hole in it! This had actually happened to me a few times with VCarve, where my material was very thick (I only have about 5.5" of Z travel).
    3 - The ubiquitous "press start" without turning the spindle on scenario... I've conditioned myself to turn the dust collector on first, then the spindle, then Start. This will be automated eventually...
    4 - The absolute/incremental I,J thing in Mach3....
    5 - Ever forget to tighten that collet nut? It's not a pretty sight...
    6 - Wrong parameters - Sometimes I type too fast, and don't bother to check what I type. Like cutting the full depth instead of setting a DOC, adding an extra zero to the feedrate, setting the plunge too high... all with equally disastrous results.
    7 - Not cleaning the dust out of my old controller. Even Jeff at xylotex said he's only seen one other instance of a phase in an axis drive go bad. It had to be me.
    8 - Impossible to weld aluminum to steel? You wouldn't think so looking at some of my bits when I first started!
    9 - Sometimes I'll do some operations on one piece using two different CAM programs. Like for quickie stuff, I'll use Cut2D. For more intricate stuff I may use OneCNC. I'd forgotten a couple times to set the work origin 0,0 to center in Cut2D, with the predictable nightmare results.
    10 - "Oh sure, the router should easily cut through that nail..." Nope - another ruined bit!
    Dec 2003
    Accidentally use M4 instead of M3 and wonder why a new cutter doesn't work?
    Mar 2003
    Shelby Twp, MI....USA
    Try to cut at 1000 ipm and 1500 rpm, because you missed a 0.
    1/2" carbide bits shatter into quite a few small pieces.
    Registered Drools's Avatar
    Feb 2009
    #5 yep.
    #3 yep but the S-PID does that now.
    #1 yep but because the tool path came too close to the screw I had holding the material down.
    #6 yep.
    Good gcode management is essential as I have ruined material by not using the revised gcode.
    I have done my share of bit snapping due to stupidity. I have thought about making a check list sign and attaching it to the router.
    Another big one I used to do was forgetting to set the proper bit/plate offset in the Auto Zero macro. For example when doing a PCB, I set the plate offset to 0 and let the bit touch the copper on the PCB. Well if I forget the plate is set to 0 and start a wood job then I’m air cutting which is ok but still a PITA.
    The Auto Zero for X/Y is different as you can get the wrong 0,0 position if the bit/plate is set wrong, which might cause cutting into a hold-down.
    Gerry said in a post, get to know the software really well, it does pay-off in the end.
    Thank You.
    Mar 2011
    Latest one was I left a razor blade on the part I was cutting and was running a drilling path sure enough it landed right on the razor blade. Spun that blade really fast. Fast enough to turn the razorblade blue and make a burn spot on the table.
    My CRP 48 x 48 build [URL="http://www.cnczone.com/forums/open_source_cnc_machine_designs/144173-crp_4x4.html"] CRP 4x4[/URL]
    May 2010
    My favorite:
    Put all clamps in place align part and start program without actually tightening any clamp. walk away to do something (never made any scary sounds) come back a minute later to see very interesting designs cut in project.
    Dec 2004
    South Africa
    Yep, i have learned (several times now) that quick is NOT fast.
    "quickly" load the next job and program and hit start....without changing the tool offsets to the new jobs tools.
    I hate it when i break a very nice new carbide cutter (or any cutter for that matter)
    Feb 2009
    Also bit handling is important, carbide bits do not react well when hitting the concrete floor.
    Thank You.
    Apr 2009
    Quote Originally Posted by ger21 View Post
    Nice! If you had 2 flutes that would have been a chipload of .333!
    Registered IBBruin's Avatar
    Jan 2012
    I'm glad to see the veterans making mistakes. I thought I was the only one.
    Feb 2009
    Pushed a turret of of square in manual. Bib boob secretary was walking by giving me the eye. I was training a new set up guy at the time. Oops.
    Registered Walky's Avatar
    Jul 2009
    Chile
    1.- Ran into a screw.
    2.- Reached the E-Stop box (wired) to have it at hand during a certain job, then accidentally dropped it causing an unwanted stop.
    3.- Did a profiling of a small circle without bridges, causing the remaining piece to get caught between the bit and the walls, ruining the piece.
    4.- Changing tools and forgetting to load the new g-code, goodbye workpiece.
    5.- Ruining a lot of material trying to find the reason for inconsistent engraving width before realizing my v-bit was dull to the point of concavity.
  • Page 1 of 3 123 LastLast
    1. Dumb question, but not so dumb??
      By gixxergary in forum Haas Mills
      Last Post: 01-09-2012, 07:30 PM
    2. Dumb Question
      By Pretorien in forum Benchtop Machines
      Last Post: 10-11-2007, 12:15 PM
    3. Really dumb question
      By ios1000 in forum Fanuc
      Last Post: 07-31-2007, 01:38 PM
    4. One Dumb Question
      By Biggermens in forum General Metalwork Discussion
      Last Post: 04-11-2007, 04:49 AM
    5. Seriously dumb CAM question
      By sploo in forum General CAM Discussion
      Last Post: 03-09-2006, 05:55 PM
