Results 1 to 6 of 6
Thread: Software
    Registered rcrabb's Avatar
    Apr 2003
    WI
    Software
    Can someone recomend a good CHEAP!!!! widndows based control program. I'm running a fet3 system from stepper world.
    Site Owner CNCadmin's Avatar
    Mar 2003
    Marh 1 is free or to get more lines of code to run it's about 100.00.
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    Shelby Twp, MI....USA
    I believe it's $150
    Mar 2003
    Also, from everything I've read, it's probably the only real option out there, Unless you look at something like DeskCNC which needs extra hardware as it doesn't use the parallel port. Mach1 / Mach2 are the only viable parallel port options under windows.
    Gold Member
    Jul 2003
    ... and it works great, too!!!
    Apr 2003
    WI
    I tried Mach 1 over the weekend. It is exactly what I was kooking for. My steppers ran perfect. Thanks for the recomendation.
    1. Engraving Software
      By The Wizard in forum General CAM Discussion
      Last Post: 03-29-2005, 06:38 AM
    2. Software sales or "license transfers"
      By metlmunchr in forum BobCad-Cam
      Last Post: 07-05-2004, 05:47 PM
    3. ***One stop CNC software guide***
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 05-27-2004, 05:31 PM
    4. What software are you using?
      By BeerFizz in forum DIY CNC Router Table Machines
      Last Post: 12-06-2003, 04:15 PM
