first of all i had set up my home switches like this:
X and Y home -> microswitches: contact = no pulse / no contact = pulse
Z home -> contact plate: no contact = no pulse / contact = pulse
but being 2 different 'modes' Mach 3 didnt home the Z correctly, he just recognised this as 'reset' and not as 'home'
now i thought if i use the same 'mode' for all swithes, being no contact = no pulse / contact = pulse, i could solve the problem...
so the Z-home stays the same but i've switched the wires on the microswitches so they gave the same pulse method as the Z-home, being no contact = no pulse / contact = pulse.
but now mach 3 can't stop 'resetting' :S
the reset keeps blinking and if i change the settings (tweeking with the 'active low' setting) ,i can get the reset to stop blinking but then my home switches dont give any pulse.
hope someone understands what i mean :P
long story short: i just want to know how to set up mach 3 correctly with all switches being: no contact = no pulse / contact = pulse.
i thought this would be simple...
LinkBack URL
About LinkBacks
