Page 1 of 4 1234 LastLast
Results 1 to 12 of 42
Thread: Any GOOD free cam software? already searched forum, no good result...
    Registered effimos's Avatar
    Feb 2012
    Belgium
    Question Any GOOD free cam software? already searched forum, no good result...
    i have already searched the forum for free cam software but found some posts but no good result.
    i now work with adobe illustrator to make DXF files and import them into Cambam for creating the toolpaths and G-code.
    but being the free (evaluation) version it can only produce 500 lines of G-code.
    this makes me have to export different g-codes of each object (because max 500 lines per export) instead of just exporting 1 g-code for the entire project.
    also being student i still need to save up some money to get a licence of cam bam.
    i am pretty satisfied about the software so i'm looking for some free replacement software that looks alot like Cambam.
    i've tried HeeksCNC and G-Simple but they can't even import my dxf files properly... they both only import some parts of the dxf but not the entire dxf file -> see the screenshots in the attachments
    so if anyone knows about other free software comparible to Cambam, please let me know
    Attached Thumbnails Attached Thumbnails Any GOOD free cam software? already searched forum, no good result...-illustrator-screenshot.jpg   Any GOOD free cam software? already searched forum, no good result...-heekscnc-screenshot.jpg
    My machine: [url]http://www.cnczone.com/forums/diy-cnc_router_table_machines/148958-my_new_desktop_cnc_router.html[/url]
    Mar 2003
    Shelby Twp, MI....USA
    This is most likely due to Illustrator's poor .dxf export. Programs like Illustrator and CorelDraw tend to export .dxf files containing mostly splines. Most CAM programs (especially fre ones) won't read splines in .dxf files.
    Feb 2012
    Belgium
    Quote Originally Posted by ger21 View Post
    thanks, i'll first try autocad then and test it again.
    Mar 2011
    I have not tried it but mach 3 comes with lazy cam. And I think the pro version is only $40.
    With that said have you checked out any of the wizzards in mach 3? most if not all of what you have there could be done using wizzards but it would take a while.
    My CRP 48 x 48 build [URL="http://www.cnczone.com/forums/open_source_cnc_machine_designs/144173-crp_4x4.html"] CRP 4x4[/URL]
    Feb 2012
    Belgium
    Quote Originally Posted by vtx1029 View Post
    lazycam is realy crappy. it's a bit too basic and he does not even recognise circles when imported from dxf, he makes octagones from every circle :s
    Feb 2012
    Belgium
    i've tried it with an autocad made dxf and heekscnc does not recognise the text and i find the program itself not verry logical, also g-simple doesn't import the dxf correctly and the program is NOT 'simple' to use. i still find cambam a better option. best to save up for a lisence key because there are no key's to be found anywhere on the internet...
    Jan 2008
    canada
    Does cnc4free and its attachments do anything for you?
    cnc4free.org homepage
    Cheers!
    Mar 2012
    Georgia
    need help too
    Hi People
    I’m Dito from Tbilisi ,Georgia
    Need help
    Maybe I’ll ask silliest questions but I’m too new for cnc field and know practically nothing. I already have new 6040 cnc (Chinese one)
    It came with the Mach3 and it’s short manual (configuration of the software.)
    The manual says nothing about homing of the machine e.t.c.
    Sorry but I have many things to ask. These are my first questions:
    1)I have made some drawings in Corel draw, is it possible to make mach3 recognize them as g codes?
    Should I format them or my Corel drawings are useless and I should make g codes in other program?
    2) maybe somebody can help me with homing of the machine 6040?
    p.s I haven't even tested the machine yet
    Please answer
    Oct 2010
    U.S.A.
    Here is an old AutoCad trick that works with AutoCad fonts (not TrueType) as well as splines and ellipses. This process will convert those entities into lines and polylines that most programs should import.
    1) Export the drawing as a Windows Metafile. (use export or "WMFOUT").
    (NOTE: For better resolution before the export, zoom in close on any entity in the drawing, do a regen, and then a "zoom previous". (may not matter on newer versions of ACAD)
    2) Now import the WMF file into a new drawing using the "IMPORT" command.
    3) Entities will come in as blocks which you can now be exploded into lines and polylines.
    4) This process usually changes the size of everything so you may need to re-scale them. Make sure you know the dimensions of something in the drawing to use as a reference, or add a line of known length to the original drawing and delete it when you are done.
    Bob
    Mar 2012
    Georgia
    thanks bob
    wow so many things to learn
    ma1
    ma1 is offline
    Aug 2010
    Pycam works for me so far (for 2-D):
    PyCAM - Toolpath Generation for 3-Axis CNC machining
    ** Don't forget to install the requirements:
    SourceForge.net: Requirements - pycam
    inkscape
    pstoedit
    ghostscript
    By the time you're done installing, you don't need any other software like
    illustrator or autocad. Inkscape will be your design tool, save to ".svg" file type. And then run pycam and import it directly. It also supports
    STL, DXF, PS and EPS.
    Mar 2012
    Georgia
    thanks
    I'm collecting the information.
    Later I'll post about what was I able to do and think that I will ask more questions.
    Glad that you people are so hospitable
  • Page 1 of 4 1234 LastLast
    1. Awesome base for Sherline 2000 Mill -- Free to a good home
      By carllance in forum Benchtop Machines
      Last Post: 12-23-2011, 12:42 PM
    2. MDF cutting result... good? pic
      By Propaganda in forum WoodWorking
      Last Post: 05-16-2010, 03:42 PM
    3. Free to a good Home
      By crash5050 in forum Want To Buy...Need help!
      Last Post: 02-24-2010, 07:20 PM
    4. Free (to a good home) Partner 6 drawbar spring
      By doug9251 in forum Milltronics
      Last Post: 10-21-2009, 11:32 AM
    5. Free DRO Software, very good!
      By DennisCNC in forum General Metal Working Machines
      Last Post: 05-27-2006, 10:23 PM
