Results 1 to 7 of 7
Thread: cable chain question
    Dec 2011
    I was wondering if there is such a thing as a cable chain that "opens" up on the top or bottom to allow you to run cables that have connectors on them that are too large to go thru the cable chain as built. The cable chain I have is big enough for the cables but not big enough to get the DB-9 connectors thru. The connectors are molded on and can't be taken off without tearing up the cable.
    Dick
    Nov 2007
    Quote Originally Posted by reeser View Post
    Dick
    there certainly is. I did a quick search on google and found numerous examples.
    Dec 2003
    Most have the ability to flip open every link?
    APT - Ametek Automation and Process technologies - Cable and Hose Carriers
    Aug 2011
    IGUS has inside-open, outside-open and fully closed chains in all imaginable sizes. There are flexible fingers on the open side that prevent the cables from escaping. Obviously the closed ones are better for heavy-duty applications with stiff cable.
    Nov 2009
    washington state usa
    I am using Igus, dont know what PN# but mine has a "zipper" the top side unzips and you can lay cables in after it is installed, then just zip it up.
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Apr 2010
    McMaster has them.
    Mar 2010
    I've gotten some chain from UGRAcnc.com. Pretty decent both price and quality. The larger sizes open, the smaller ones don't.
    1. Plasma cable in drag chain?
      By johndjmix in forum Plasma, EDM and other similar machine Project Log
      Last Post: 02-20-2012, 01:58 PM
    2. My Dragon Cable Project (E-Chain)
      By msimpson99 in forum DIY CNC Router Table Machines
      Last Post: 09-13-2011, 04:34 PM
    3. Cheep cable chain.
      By cliffy in forum EBAY ADS
      Last Post: 07-18-2011, 04:59 PM
    4. Newbie- cable and chain drives
      By stepperhead in forum DIY CNC Router Table Machines
      Last Post: 04-01-2009, 08:41 AM
    5. cable carrier / chain
      By hpghost in forum Open Source CNC Machine Designs
      Last Post: 05-02-2007, 09:10 AM
