Thanks for your response AWERBY.
Today I hooked up the 3axis TB6560 Controller Board to my PC and with Mach3. Trying configuration of my step motors on the work bench. GOT REALLY F--King Mad. I did many configurations, almost all have step failures. So I went to the forums in this site and everyone says this controller isnt worth sh--. I am going to forget this controller.
[Before you forget it, try loading those motors a little, then testing them again. Steppers need something to push against; they don't bench-test well. So put a pulley on the end and attach a weighted string to it, and see if it behaves better. Start with a slow speed and low acceleration, and slowly increase it until you notice faulting.]
Advise: DONT BUY CHINESE TB6560 CONTROLLERS
[There's a rather lengthy thread on them here: http://www.cnczone.com/forums/genera...y_chinese.html ]
!! I am thinking of buying a gecko g540. Is the g540 a good buy? Does the g540 work with my nema23 chinese motors (57BYGH76-401A), or should I also forget the motors also?
[The motors are probably fine. The G-540 is a really nice controller board, which integrates the function of a breakout board and 4 drivers. It offers 10x microstepping, and can handle up to 50v from the power supply. I've set one up to run a Taig mill and have been quite pleased with its performance.
By the way, I don't believe that micro-stepping cuts torque much, if at all. It certainly doesn't do it in the linear progression that was claimed above, or these 10x microstepping drives would barely be able to move. Micro-steps don't really add to the accuracy of a system, but they do smooth out resonances that can cause lost step errors.]
Thanks to all for your help.
Sorry for my bad English.
