Page 3 of 5 FirstFirst 12345 LastLast
Results 25 to 36 of 58
Thread: G540 wiring questions
  1. #25
    Tinkerer
    Nov 2009
    Quote Originally Posted by Vestus View Post
    Stranded isn't usually used for cabling runs but for sections that get moved often, like patch panels, cnc routers, etc. If you look carefully at the wires in the plug, you can usually tell if it's stranded versus solid.
    I wouldn't know about punching it, I always crimp on plugs.
    Like on an ice cube (RJ45?), male needs crimping, female needs punching. There are many more products and techniques than I am familiar with. I use mostly Leviton. However use of solid wire would be fine if you left an unstrained arc of sufficient diameter and tied down the wiring near the connections. Though stranded would be best for movement.
  2. #26
    Registered kinghong1970's Avatar
    Apr 2009
    just to reconfirm before i click the purchase... what gauge wires recommended for connections to G540 to e-stop, limit, probes?
    i have some 22 AWG shielded, seems much thinner that what i see in many build logs.
  3. #27
    Mar 2003
    Shelby Twp, MI....USA
    I use 22 gauge for everything, and my stuff works.
  4. #28
    Mar 2010
    22 shielded is ideal for inputs. No need for anything bigger.
    About the only thing you can think about is that the most easily available shielded wire is foil shield. That's great for things that don't flex. If you have a run that is in an e-chain, it's desirable to have something like braid shield (microphone cable for example).
    Having said that, lots of DIY machines have foil shielded wires and they seem to work okay.
  • #29
    Registered LouF's Avatar
    Sep 2011
    So after reading this thread I run a Gecko 540 I have 3 home switches and 3 limit switches on my machine right now. I have my limit switches wired in a series If I wire home switches in a series that would free up room to hook up a touch plate I am wired like the image below at this time?
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
  • #30
    Registered BanduraMaker's Avatar
    Dec 2010
    There's really little reason to have them wired into separate inputs unless you modify Mach 3 for simultaneous homing.
    In fact, there's few reasons to not wire your limit switches in series with your home switches.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  • #31
    Sep 2011
    I just followed the instructions of my CNC manufacture all in one series?
    Lou
  • #32
    Dec 2010
    You most certainly can. There are a couple of reasons for having separate home & limit connections, the big one is having a home switch in a different position than a limit (e.g. you'd need more than 6 switches for a 3 axis machine).
    I suppose if you don't need the inputs for anything else, there's certainly no harm having them wired separately. And, it's definitely less work to leave it how it is.
    -Andy B.
  • #33
    Sep 2011
    I will hook up my home switches in a series and leave the limit switches hooked up in a series that will free up two more connection points.
    Thanks Lou
  • #34
    Oct 2010
    I dont know if this will help but I was planning on putting my limit switches on the e stop through a momentary switch so the machine could be moved if it hit one. That would free up another one of your inputs
  • #35
    Sep 2011
    The NC,NO & C on my limit switch's to run the home switch"s in a series do I wire the same as my limit switches using the C,NC right now they are wired like the diagram above C,NO.?
    Lou
  • #36
    Mar 2003
    Yes, to run them in series you have too use the normally closed (NC) terminals. They won't work in series using the NO terminals.
  • Page 3 of 5 FirstFirst 12345 LastLast
    1. Wiring Gecko G540 to PSU
      By rnm85 in forum DIY CNC Router Table Machines
      Last Post: 01-07-2012, 08:48 PM
    2. g540 complete wiring
      By bel630 in forum Gecko Drives
      Last Post: 08-31-2011, 07:01 AM
    3. Need Help!- X2 G540 Wiring Question
      By Steoh in forum Benchtop Machines
      Last Post: 03-01-2011, 07:53 PM
    4. Wiring a G540 into 4 axis Xylotex box
      By justCNCit in forum General Electronics Discussion
      Last Post: 11-27-2009, 06:12 PM
    5. G540 Wiring
      By clamps in forum Gecko Drives
      Last Post: 07-16-2009, 12:41 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
