Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: CRP2448 build plan: is it rigid enough or is it just plain overkill?
    Registered kinghong1970's Avatar
    Apr 2009
    So i'm putting together plans and sketches of the 2x4 router... and the word "rigid" must have been in my mind throughout.. as now, when i look at it.. .i worry if this is overkill...
    so, the color chart is as follows:
    Axis Beams
    X-Axis Base: 1545 extrusions (d.blue)
    Y-Axis Base: 1530 extrusions (l.blue)
    Gantry
    typical CNCRP gantry (not illustrated... yet)
    Cross Members & Legs
    y-length cross members: 1530 extrusions (l.blue)
    x-length cross members: 1530 extrusions (pink)
    4 legs: 1530 extrusions (l.blue)
    SUPPORTS
    "http://www.amazon.com/80-20-Inc-Series-Support/dp/B006YVZ42S/ref=sr_1_1?s=industrial&ie=UTF8&qid=1331859288&sr=1-1"]#2535 15 series 45 deg 12" support (lime)
    BRACKETS
    "http://www.amazon.com/80-20-Series-8-HOLE-INSIDE/dp/B001IA4PP2/ref=sr_1_1?s=industrial&ie=UTF8&qid=1331858991&sr=1-1"]#4338 15 series 8 hole inside gusset corner bracket x8 (at each corner only)
    "http://www.amazon.com/80-20-8-HOLE-INSIDE-BRACKET/dp/B001IA2MD4"]#4304 15 series 8 hole inside corner bracket (at each mid area cross member)
    now, the 4304 red brackets, i did find a very good deal for some mis-drilled lot... so it's done... but wondering, can i actually get by with just 1515 instead of 1530 on the lower horizontal cross members of the build?
    do you see anywhere else that needs supporting?
    i was also considering using 4301 under the legs to hold them in place... overkill?
    thanks in advance
    Al
    Registered lgalla's Avatar
    Jul 2006
    canada
    Al there is no such word as "overkill"when designing a CNC machine.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Apr 2009
    Talking
    Quote Originally Posted by lgalla View Post
    Larry
    Larry... i like your style
    /opens 80/20 catalog...
    Apr 2009
    I don't think you could build a machine 'ridgid' enough! The only limiting factors are you budget, means, and needs.
    Apr 2009
    ok, so let me ask the better question...
    where can i trim the fat?
    i would like to put some plates on the outer corners of the x-axis with the legs and seems i'm too dense in the inner brackets...
    thoughts?
    if it were you, what would you add?
    Apr 2007
    Mounting your rails to a large chunk of tombstone granite is just about rigid enough for the frame, but the rails and gantry can, and will, flex.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2009
    should i add another vertical support mid way along the X-Axis? between the blue and pink?
    and from pink to the floor?
    i think putting granite slab is out of the question for me.. lol?
    Jul 2006
    canada
    overkill
    Al here is an example of overkill...One of the zone members did beam deflection calcs for me with Beam boy.Picture a 4"x12" 1/4" beam,gantry 100lbs centre load
    The deflection was .0001.If a fly landed on the centre of the beam the deflection would be....0000000000000000000004563 Over kill?possibly
    I did a trade show for a Japan company and they were showing their mini mill,the smallest they produce.50HP spindle.40,000lbs 5" ballscrews,,30 tool changes.The base to floor had hundreds of brackets and bolts to fine tune the mount.Overkill?Yes
    Apr 2009
    thanks Larry... i think i saw a mill similar to that you mention when i was at Tokyo... a nifty lil store called Tokyu Hans... love it... had the smallest mill and lathe i've seen.
    i guess i can get the parts, build it up and then make a decision.
    Apr 2009
    I want one!
    Apr 2007
    I am not sure if it makes sense or not, but my own plan is to more or less take a box like that, and build the router inside of it, rather than on top. That way you get:
    - An enclosure
    - solid bracing
    - close to the floor for minimum shake
    And - the top can be a work bench.
    Apr 2009
    Quote Originally Posted by kinghong1970 View Post
    I guess the real question before you ask if it's overkill, is what are you cutting? If it's balsa and foam, the answer may be yes. It may be no. If you were cutting stainless steel, probably not. I guess overkill is relative.
    On my latest build, I'm using 5050 for the table rails, 50100 for the table ends and gantry uprights, and 100200 for the gantry beam, with a 3/4" cast aluminum plate for the table. For cutting balsa, maybe overkill. For aluminum, it's probably adequate. For steel, I'm not too sure. And this is a 2x2 cutting area...
  • Page 1 of 2 12 LastLast
    1. Newbie- Just begining to plan a build, looking for input
      By ViriiGuy in forum DIY CNC Router Table Machines
      Last Post: 07-10-2011, 11:07 PM
    2. Newcastle: Beginning of build plan
      By pippin88 in forum Australia, New Zealand Club house
      Last Post: 09-16-2010, 05:22 AM
    3. Questions for a 5x10 build plan
      By rpgdeity in forum General Waterjet
      Last Post: 10-28-2008, 08:05 AM
    4. Newbie- on the hunt for a small 3 axis home build plan
      By RichB77 in forum Vertical Mill, Lathe Project Log
      Last Post: 10-17-2008, 05:05 PM
    5. Build Log - hack's plan
      By bryanrabb in forum DIY CNC Router Table Machines
      Last Post: 03-23-2006, 10:57 AM
