Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Z-Axis Design
    Feb 2011
    Z-Axis Design
    Hi everyone, I have been reading through the forum and haven't been able to find anything (but I'm sure there is) about my z-axis design. I have seen the design on youtube and some pictures elsewhere but I would like to know what people think.
    Rather than mounting the rails on the X-Axis plate, why not mount the bearings on the X-Axis plate. This way as the spindle move up on the Z-Axis the rigidity should improve (spindle will be closer to bearings).
    I want to be able to machine a maximum of aluminium, whilst also softer materials. So if I were to cut aluminium I could increase the thickness of the sacrifice board so the Z-Axis will the cutting higher. (Does this make sense)
    I'm trying to keep the Z-Axis with a machining area of 220mm.
    This makes sense to me but I'm wondering why others haven't done it.
    Cheers
    Attached Thumbnails Attached Thumbnails Z-Axis Design-z-axis.jpg   Z-Axis Design-z-axis_2.jpg
    Registered DonFrambach's Avatar
    Nov 2006
    Actually, lots of people do it this way.
    Here's a link to a photo showing it on my current build with linear acturators:
    http://www.cnczone.com/forums/diy-cn...ml#post1051005
    Here's a link to a photo showing an earlier version with parts from CNCRouterParts.com:
    http://www.cnczone.com/forums/diy-cn...tml#post843806
    Feb 2012
    England
    I'm no expert but I'm thinking thats adding more weight to an already heavy axis thats supporting the spindle and axis itself if made out of thick aluminium,I mean it can't be healthy for the stepper motor?
    Feb 2011
    Thanks for the replies its nice to know I'm not breaking away from the crowd!
    HorridHenry you say it will add more weight. I should say as well I'm having a fixed gantry with a moving table (Y-Axis). So the extra weight would only be for the Z-Axis motor. I may need to gear down this axis.
    The details of the design need to be finalised. Like how to fit the ballscrew. The rails and bearings are only 30mm deep which isn't enough room for the ballscrew which needs a minimum of 45mm.
    Apr 2010
    I have never once heard someone say "I wish I had built my table lighter." Only stronger.
    Weight in the right places is good. Weight in the wrong places doesn't make much difference. The heavier you make your components the less it will flex. I say beef it up- the cost is not much different and you will be much happier with the results.
    Feb 2012
    England
    Yeah but....the floorboards will.
    Feb 2011
    crane550 do you think using 10mm steel plate would give it that extra weight minimising vibration. I do tend to forget that the overall mass of the machine is very important.
    I have a question about linear rails. How interchangeable are the linear bearings. Is it possible to put thk bearings on to a nsk rail? Also if the linear bearings don't have ball bearing retainers how do you change them over??? Specifically are nsk sh20 linear ball bearing retained?
    Cheers.
    Apr 2009
    I also have my rails mounted on the carriage plate, exactly for the reasons stated. There's always some debate over this, but I agree. When you have the carriage all the way up, the collet/bering block distance is at its minimum; this is the best case scenario. When the carriage is all the way down, the collet/bearing block distance is at its maximum; this is the worst case scenario. Mounting the rails to the carriage plate does add the mass and ridgidity to that part; sizing your motor and screw right will ensure it moves right.
    If you mount the rails to the saddle (or bearings to the carriage), the bearing blocks must be arranged on the carriage so that it is the maximum distance from the collet to allow for the same amount of travel; in other words, the collet/bearing block relationship will always be at a worst-case scenario.
    The exception to this is if your Z axis travel is minimal, and you can space the bearing blocks farther that the distance between their ends is a majority of the total length of the rail.
    I feel the moving rails design gives more flexibility; more travel; and simplifies the carriage design. On the flip side, it is not as easy to compact all the linear motion components.
    The moving bearing design is easier to implement, since mounting rails to the saddle doesn't present the screw clearance and installation issues that mounting the bearings do. But it may not be the best choice if you need more Z travel.
    So in conclusion there are pros and cons to both ways, and you need to base your design on your needs, components used, and ability.
    As far as I know, you cannot interchange blocks and rails from two different brands. In fact you cannot interchange them with different series from the same company. For example, a THK SHS block will not fit a HSR rail. You could, however, use a HSR-C or HSR-A or HSR-LC, etc. block with an HSR rail. Also if I recall correctly you should be able to remove any THK block past 15 series from the rail, since the bearings are retained in the block. It is a good idea however to put the blocks on a stub rail or holding jig, since dropping the block could loosen the bearings, and you'd protect the bearings from contamination.
    Feb 2011
    Hi louieatienza, thanks for your detailed response, much appreciated. Have you any thoughts about where the best place is to mount the ballscrew and motor?
    The ballscrew bearing mounts could be mounted on either the carriage plate or the x-axis plate. I prefer the idea of the motor mounted on the x-axis plate so its stationary in the vertical direction. Mounting the motor on the carriage would mean its moving up and down vertically....not so keen on this.
    What do you guys think?
    Apr 2009
    Quote Originally Posted by WB-1 View Post
    On my current machine, the leadscrew and motor are both mounted to the gantry saddle. It's actually a modified Solsylva plans design. On my new machine, I will add a plate perpendicular to the saddle and mount the motor upside down, and run the ballscrew via timing belt and pulleys.
    Registered Falcon69's Avatar
    Jan 2012
    Vancouver, WA
    WB-1
    Take a look at my build. The z-axis is louieatienza approved! LOL
    Anyway, the holes on mine were to just lighten it abit, but after talking with the folks who might be cutting it out on their waterjet advised me not to, as the cost is per inch the machine moves. So it adds up quick.
    You may want to take that into consideration when you build your machine. As others has stated, heavy and ridgid is better. I'm new at this as well. So only advise I can give is take your time on designing and do it right. Draw it up 3, 4, or even 50 times if you have to, and only cut it once. Steel is expensive.
    Watch ebay, craigslist, anything you have access to. Pay close attention to auctions and such, you may just find yourself getting a nice deal on some parts, like Profile Rails and Blocks, Motors, etc. There has been a few members on here that have gotten lucky and gotten some really nice deals on used, and new, equipment. Take your time and keep a look out.
    I made a mistake and bought rails and pillow blocks for my z-axis, as well as a break-out-board before getting the much needed advice. Now I'm stuck with parts I won't be using. Just take your time, ask lots of questions, and don't buy stuff more than once. Keep your costs down.
    As a newbie/beginner in CNC, much like yourself, this is the best advice I can give you. G'Luck on your build!!!
    Feb 2011
    Hi Falcon69, I appreciate your comments. Would your machine be capable of cutting aluminium? I see the y-axis is belt driven. Belt driven axis are a lot cheaper (from first impressions) but I would have thought the belts wouldn't be capable of cutting aluminium???
    What do others think about this??? Any examples of aluminium cutting/belt driven machines.
    Your z-axis design seems very complicated and intricate for what real gain???
    I would say the stationary bearing/moving rail design is the way to go for the z-axis.
  • Page 1 of 2 12 LastLast
    1. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
      By the__extreme in forum CNC Wood Router Project Log
      Last Post: 02-26-2007, 03:58 PM
    2. Now....the Z-Axis Design ?
      By CNCadmin in forum DIY CNC Router Table Machines
      Last Post: 12-07-2006, 02:00 PM
    3. Now....the Z-Axis Design ?
      By RakmUp in forum DIY CNC Router Table Machines
      Last Post: 11-29-2006, 04:24 PM
    4. Help With Z-Axis Design
      By JavaDog in forum DIY CNC Router Table Machines
      Last Post: 06-11-2006, 09:12 AM
    5. 4th axis design
      By mocnc in forum DIY CNC Router Table Machines
      Last Post: 10-07-2005, 05:53 PM
