Page 3 of 3 FirstFirst 123
Results 25 to 28 of 28
Thread: G540 and Mach3 set up
  1. #25
    Oct 2004
    You can reverse the axis in Mach 3. I don't have Mach in front of me right now but I think it's in the Ports and Pins screen. There should be an option (check box) to Reverse Axis.
    Chris
  2. #26
    Dec 2011
    I had a look but could not find where to reverse axis. I have installed the current version of mach3 also and now files have some added/unwanted circles? I did not draw these circle and it as if they are added to all my saved files. Is this becuase of the newer version of mach3.
    I have got about 50 to a 100 saved coral files that i used cut2d to make my Gcodes. This all worked fine until i changed over from xylotex to G540 and updated to the current mach3 version.
  3. #27
    Nov 2007
    Quote Originally Posted by chiefcnc View Post
    You should find it under Config - Homing/Limits
  4. #28
    Dec 2011
    Changed direct low in motor outputs and it has fixed problem. This has reversed the axis. I now have my original files cut the same as before.
    The unwanted circle was fixed by changing a setting in config.
  1. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-02-2012, 11:10 PM
  2. Need Help!- g540 / superpid / mach3
    By daniellyall in forum Gecko Drives
    Last Post: 10-03-2011, 04:15 PM
  3. Need Help!- Setting up X and Y G540/Mach3
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 03-07-2011, 06:46 PM
  4. Mach3 + SmoothStepper + G540 = No go
    By CarbonKevin in forum Mach Software (ArtSoft software)
    Last Post: 11-23-2009, 06:09 PM
  5. G540 Mach3 XML File
    By CoAMarcus in forum Gecko Drives
    Last Post: 11-08-2008, 12:38 AM
