Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 31
Thread: New ACME nuts from DumpsterCNC and CNC Router Parts
  1. #13
    Apr 2007
    Quote Originally Posted by dumpster View Post
    CarveOne: The 11 pound router shouldn't be a problem for a single leadnut, although using 2 leadnuts back to back will obviously make it stronger. The nuts can't be rotated in the mount since they screw in and have the added security of the jamb nut to lock them in. To get 2 leadnuts lined up properly, you'd need to be able to shim between them to get the correct distance. A pair of slots in the mounting plate would allow you to adjust one of the mounts in either direction.
    BTW, my machine isn't miles long either, I had to make 2 passes!
    Tim
    Thanks for the confirmation. It would be 11 pounds plus the weight of the vertically moving part of the Z assembly. Something around 15 pounds hopefully. I previously figured that I could use two of your round flange nuts, screw the flanges against each other, drill holes through both flanges and bolt them together to get one longer nut with a flange that I can cut to shape as needed. I may still do it that way for this router and use these new ones or your original ones for any future machines with lighter routers. I like the 90 degree aluminum mount arrangement. I've been doing it by cutting the round flange and mounting the nut to a piece of steel angle.
    Will you and Ahren both be selling these new ones or just Ahren?
    edit: These will have some backlash. Get ready for the flood of orders.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  2. #14
    Registered ahren's Avatar
    Feb 2004
    Carve,
    Initially only we will be carrying the mounts, but you can order the nuts from either of us. We have about 500 currently in stock in anticipation of the flood
    Best regards,
    Ahren
  3. #15
    Apr 2007
    Quote Originally Posted by ahren View Post
    Carve,
    Best regards,
    Ahren
    Sounds good. I would go bonkers making 500 of any one thing. Glad somebody can do it.
    CarveOne
    CarveOne
  4. #16
    Registered LouF's Avatar
    Sep 2011
    Ahren, will these work on my FLA-100 I am think about extending it out?
    Lou
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
  5. #17
    Feb 2004
    Lou,
    Yes, Fine Line uses our ACME nuts so these will work for their machines as well.
    Best regards,
    Ahren
  6. #18
    Sep 2011
    Ahren, Cool thanks..
    Lou
  7. #19
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by CarveOne View Post
    Sounds good. I would go bonkers making 500 of any one thing. .
    CarveOne
    Not if you had one of these.
    http://www.youtube.com/watch?v=Y1IDHIcyHLY&feature=related]Scratch built CNC Slantbed Lathe - RUNNING! - YouTube
  8. #20
    Sep 2011
    Gerry nice machine very impressive..
    Lou
  9. #21
    Registered Grunblau's Avatar
    Jun 2008
    Michigan, USA
    Hmmm...
    Just when you think you have collected all of the parts for a new build....
  10. #22
    Registered DonFrambach's Avatar
    Nov 2006
    ... Tim can produce the nuts in any of his standard ACME configurations (single start, two start, 5 start, etc.), and we're happy to sell the mount separately if you want to go that route.
    Best regards,
    Ahren
    CNCRouterParts
    Does that mean that Tim will soon produce the nuts in single start configuation? I would really like to get one of them! (actually 2 so I'll have a spare)
    Don Frambach
  11. #23
    Apr 2007
    I just knew that had to be Tim's machine. Yeah, that would take some of the pain out of it for sure Gerry.
    CarveOne
    CarveOne
  12. #24
    May 2010
    Moore, Oklahoma, USA
    Ahren,
    Great to see these. Are they a simple swap for your other nuts or are they taller/shorter?
    Roy
  1. Just IN- CRP / DumpsterCNC Anti-backlash ACME Nuts!
    By ahren in forum Product and Manufacturer Announcements
    Last Post: 03-17-2012, 03:07 PM
  2. anti whip block needed with dumpstercnc nuts?
    By forgetcolor in forum JGRO Router Table Design
    Last Post: 05-16-2009, 12:33 AM
  3. New ACME Couplers at dumpsterCNC
    By dumpster in forum Product and Manufacturer Announcements
    Last Post: 03-16-2009, 11:00 AM
  4. i need some acme nuts
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 01-27-2004, 01:33 PM
