Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Cheap Lead Screws ?
    Aug 2011
    UK
    Cheap Lead Screws ?
    Anyone else get thoughts Like this ?
    https://www.rutlands.co.uk/cgi-bin/p....cgi?promo=105
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Feb 2012
    England
    Aug 2011
    UK
    Quote Originally Posted by HorridHenry View Post
    not the same !
    Threaded rod, doesn't have the load rating of square cut ACME (Trapezoidal). That's why I'm changing my Z rod, that I used, just to prove the Z design.
    I concede, it might not be that accurate, but most machine drivers these days have mapping capabilities.
    Feb 2012
    England
    How about this?......
    WMH Transmissions Ltd - Product List - SIZE 20MM X 4P R.H.
    They charge £15 for their shipping but an alternative cheap courier can be arranged if you phone up ie RoyalMail
    Aug 2011
    UK
    Still more than the £10 each of the 1st link.
    That was the Tamworth link I said I liked last time you linked it. Their Rack and pinion is a very good price !, as are their screws.
    It's only about an hour away from me, so I'll probably collect if I order. (3m lengths are usually expensive to ship ! )
    Feb 2012
    England
    I don't know what size to get?
    I'm thinking 18mm or 22mm
    Feb 2012
    England
    Weird,the 20mm is £16 odd and the 18mm is £20 odd,gotta be a mistake in the pricing?
    Aug 2011
    UK
    whatever the price, remember a larger Dia screw for a given length takes more torque to spin up and slow down, so it depends on your application.
    Registered robe_uk's Avatar
    Apr 2005
    Northern Ireland
    @trickycnc, am not sure what you are trying to show in the links with the clamps as the acme screws look to only be about 6-8inch long so would only be of use for z axis if you can get a matching nut.
    @HorridHenry, size of rod would all depend on your design, length of axis and size of motors, pricing might be correct as the 20mm might be a more standard size hence lower cost, worth a call to confirm.
    I got my rack and pinion from whm so can fully recommend their service.
    Rob
    opps see tricky posted as i was typing
    I'll get it finished sometime after I start it.....
    Feb 2012
    England
    My bed is 800mm long, working area about 700mm
    220 oz stepper motors.
    No I think its a mistake in price as 22mm is lower than the 20mm
    Feb 2012
    England
    Deleted the bookmark so will have to find it again.
    The guy made ballscrews out of Derlin, he cut square Derlin in half,heated up the ACME rod and pressed the two halfs together with a clamp and at the same time heatimg the ACME rod up with a paintstripper gun until the two halfs of Derling met together,let them cool then cleaned em up basically he was maing half nuts but I think once the operation is completed we could glue them together with superglue or Araldite and use a ballnuts.
    Aug 2011
    UK
    Quote Originally Posted by robe_uk View Post
    DOH !!!
    you are correct.. I am completely wrong ! LOL
    I pictured in my head 1m long threaded rod, but of coarse it's not .
    Rich
  • Page 1 of 2 12 LastLast
    1. Cheap ACME Lead Screws
      By mjarus in forum Linear and Rotary Motion
      Last Post: 05-03-2006, 10:22 PM
    2. Lead Screw Bearings - Cheap is OK
      By musicmkr in forum Mechanical Calculations/Engineering Design
      Last Post: 01-07-2006, 06:21 PM
    3. Need cheap source for acme lead screw parts
      By Hack in forum DIY CNC Router Table Machines
      Last Post: 02-22-2005, 12:10 PM
    4. Cheap UK Lead Screw, but is it any good?
      By MrBean in forum DIY CNC Router Table Machines
      Last Post: 02-15-2004, 01:59 AM
