Page 1 of 3 123 LastLast
Results 1 to 12 of 36
Thread: My 1st purchase towards my cnc machine. Did I get a Good deal?
    Feb 2007
    Hi All,
    So after several weeks of reading this forum I stated designing my cnc machine. I want a 24" x 36" working area with the ability to cut wood and aluminum (guitar bodies, necks and brackets).
    I was leaning towards round linear supporting rails but I came across a pair of 460mm rails with 4 THK HSR 20 blocks for $85 shipped, used and in great condition. I was just trying to get an idea of how much this machine will cost me to build when I came across these.
    I'm hoping to cut them shorter since they will be for my z axis.
    Also, I didn't realize how long of a rail I need until I started designing my machine. For example, a 12" rail will not give you a 12" cutting area because you have to take into account the bearing length, 2 for my machine, and the length of the piece you are mounting your bearings to.
    Anyway, I hope I'm off to a good start.
    newpatch
    Feb 2012
    England
    Heh? your z axis will be to short,unless you mean cut them down for your Y axis
    The Z axis goes from left to right
    The Y goes up and down
    The X axis is the bed length
    Feb 2012
    England
    This is correct,so if you want a 24"x36" working area you need at least 28"x40"
    I wouldn't cut those rails down just yet until you have finally near enough built the machine,seriously
    Gold Member lovebugjunkie's Avatar
    Apr 2005
    Quote Originally Posted by HorridHenry View Post
    Most builders in the USA mount their spindle on the Z and it moves vertical to the table. My guess we do that to stay in sync with CAD programs that have the Z doing the same thing.
    I think you got a good deal newpatch, and I would not cut them down, just use them as is, never can tell when you might want a few extra inches in the future.
    Registered BanduraMaker's Avatar
    Dec 2010
    There seems to be some arguments about which is X and which is Y on this forum but I don't think anyone ever has a Z that goes anywhere but up and down.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Feb 2012
    England
    There does doesn't there.....
    Attached Thumbnails Attached Thumbnails My 1st purchase towards my cnc machine. Did I get a Good deal?-coordinateaxesnsew.whitebackground.jpg
    Dec 2010
    You're thinking of a lathe coordinate system. For a mill it's Z up, X & Y parallel to the ground.
    machine coordinate system cnc - Google Search
    -Andy B.
    Feb 2012
    England
    I'm not thinking of anything other than googling for XYZ axis
    Dec 2010
    Did you even follow the link I posted?
    -Andy B.
    Feb 2012
    England
    The cartesian method is what I got taught in school.
    Dec 2010
    Oh, in that case we'll just have the whole world of CNC change so that we can communicate with you.
    To the OP, that does seem like a good price. For a Z-axis, you probably don't need two trucks per rail. One should be plenty strong. If you take one off, be careful though as the ball bearings will fall out. There's a little rail shaped gizmo you can use to remove them without losing the balls.
    -Andy B.
    Feb 2012
    England
    So long as I don't have to get in a space shuttle with you.
  • Page 1 of 3 123 LastLast
    1. Need Help!- Found Used Machine. Good Deal or Not?
      By zild1221 in forum General Metal Working Machines
      Last Post: 02-20-2012, 06:45 PM
    2. Is this a good deal for a '96 VF-2
      By dingo0722 in forum Haas Mills
      Last Post: 12-01-2010, 12:39 PM
    3. wow, somebody got a good deal
      By KTP in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-31-2009, 10:35 AM
    4. Newbie- Good deal?
      By geales1989 in forum General Metal Working Machines
      Last Post: 04-06-2008, 09:15 PM
    5. Good Deal or Not?
      By DroopyPawn in forum Benchtop Machines
      Last Post: 12-03-2007, 09:36 AM
