Results 1 to 10 of 10
Thread: Mechanical Vs. Inductance Limit & Proxy switches
    Apr 2010
    Been searching Google and have not found much so far. I was wondering if someone had a known good supplier on a decent proxy switch. I have seen them from a couple bucks each to 100's, and not really sure what most people are using. I think I want to go with the inductance type. Anyone have any experience with them? Once I get it figured out I will try to write up a schematic to share of how I got it all working.
    Mar 2011
    I've used a bunch of Keyence ones. They work good but are $$$.
    I made some hall switches for my machine. Electronic home switches made easy!
    Aug 2008
    I used the mechanical Microswitch kind for about 3 years now, they work fine. Decent repeatability.
    On my new machine i bought 4 of these: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    I think they are going to work better than the mechanical style, only time will tell.
    I was going to build the Hall effect switches from the "home switches made easy" thread, but I had trouble finding the proper parts and didnt feel like making a housing for them. The ebay ones were a good tradeoff.
    Dec 2003
    Automation Direct sell Proximity switches pretty cheap.
    Feb 2008
    I use automation direct stuff all the time, good products and good prices. Expect to pay about $18.00 each. If you are feeling really crafty you could do what I did. Purchase hall effect sensors (5 pack on ebay for $7) and make your own sensors. These tiny sensors are hard to mount but after soldering the wires on I put them in a brass tube and filled them with epoxy. Now they are easy to mount, add a small magnet and you have a very accurate solid state sensor. I have three of these on my machine.
    Scott
    Dec 2007
    These ones are all over Ebay. New LJ12A3-4-Z/BX Inductive Proximity Sensor Switch NPN DC6-36V | eBay
    If they work properly, then it does not get much better than that.
    Dec 2003
    I can never figure out how they can include shipping from Hong Kong on items like this?
    Aug 2008
    Quote Originally Posted by LazyMan View Post
    Darn, thats a great price. wish I had seen those, although they require a different mounting method than the ones im using. So cheap..
    Apr 2010
    Those might just be what I'm looking for assuming they are accurate enough. For $12 I can get the 3 needed for my machine shipped....? It's worth a try! Worst case they can be used for a limit switch later on another machine.
    Dec 2007
    If you try them out let us know how well they work.
    1. Proximity or mechanical limit switches?
      By gearsoup in forum DIY CNC Router Table Machines
      Last Post: 04-01-2011, 06:16 AM
    2. Need Help!- Home switches and Limit Switches
      By TheBulk in forum DIY CNC Router Table Machines
      Last Post: 03-12-2011, 06:08 AM
    3. Optical vs Mechanical Limit Switches
      By ronncat in forum Benchtop Machines
      Last Post: 01-02-2011, 10:08 AM
    4. The relationship of limit switches to home switches.
      By MikeAber in forum General Electronics Discussion
      Last Post: 11-04-2004, 02:28 PM
    5. Limit switches and home switches
      By viktorcnc in forum TurboCNC
      Last Post: 08-03-2004, 07:11 AM
