Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: Linear Carraige or Linear Motion Round Support Rails
    Feb 2007
    Hi All,
    Is one better than the other?
    Accuracy, price, load, etc.
    Trying to decide which one I should plan for in my design.
    newpatch
    Mar 2003
    Shelby Twp, MI....USA
    What are you referring to when you say "linear carriage"?
    Feb 2007
    Sorry, should have been specific....
    These:
    CNCRouterParts
    The bearings from CNC Router Parts..
    vs these:
    linear bearing rail 2 SBR16-350mm support rails+4 SBR16UU blocks (with bearing) | eBay
    newpatch
    br1
    br1 is online now
    Oct 2006
    I got some 20mm from Glacern tools, work pretty good, I use a little White Lithium Grease. No problems yet. 1 year old.
    Aug 2008
    The 20mm Rails from Glacern are great, and the price is excellent. I cant speak for the CNCRP carriages but I think the round rails are going to be a better solution.
    Do bother with 16mm Round rails, they are really too small for a cnc router. You'll be surprised at how small the 20mm rails already are, I know I was.
    Feb 2012
    England
    I think he means "Don't Bother".
    25mm or over is ok,the bigger the better and what you can afford?
    Apr 2010
    Yes, I would also go with the 20mm rails. They are not much more expensive then the 16's, so that is a no brainier in MHO.
    Over all, I think the 20mm rails are a more professional solution then the CRP option, but the CRP makes building really easy.
    If you really wantto get nice, check out the HSR or SHS 20's from THK. You can find them used for decent prices, and can't go wrong there.
    Feb 2007
    I was going with the 20mm for my project...the 16mm link was just for a visual.
    I would also go for the square rails but I'm thinking they are out of my budget. I've seen linear motion round rails on ebay for a good price, a set of 3, one for each axis. Some of the members here have purchased them and are happy...
    Things might change, but so far they are in my design which is a 2ft x 3ft cutting area machine....
    newpatch
    Feb 2012
    England
    To be honest there is no substantial difference between 16mm and 20mm really when you look at the diameter in your hand.
    You need at least 25mm to shy away from 16mm,an extra 4mm is nothing.
    Apr 2010
    Quote Originally Posted by HorridHenry View Post
    I would respectfully disagree. Area of a 16mm radius circle is 804mm^2. Move up to a 20mm rail it now becomes Pi(20)^2 which is over 1200 mm^2, roughly 50% more mass. Considering that bending strength is correlated with mass^2, the difference is exponential.
    I would agree that moving to a 25mm rail is much stronger yet (the same math applies), but there is a huge difference between a 16 and 20mm rail.
    The weak point, however, is not the rails, its the bearings. I am not sure if the 20mm bearings are 50% again stronger then the 16's, you will have to look at the ratings.
    Feb 2012
    England
    Sorry but equations don't fit into my vocabulrary when comparing size of round rail that are so close in size to each other,I like to see with my own eyes the difference.
    Get a caliper and find two disc,1 of 16mm and 1 of 20mm its hardly worth changing from 16mm to 20mm because the difference is minimal.
    Mar 2003
    And the difference from 20mm to 25mm is just as minimal.
    If you look at the static load ratings for a single open carriage at VXB, you get:
    16mm = 1180N
    20mm = 1370N
    25mm = 1570N
    Using the 20mm shafts, you get 87% of the capacity of the 20mm shafts, for about half the price.
  • Page 1 of 3 123 LastLast
    1. If you could do it again... How would support your linear rails using 8020?
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 12-22-2009, 08:53 PM
    2. Linear guide rails..flat vs round
      By cloudbase in forum DIY CNC Router Table Machines
      Last Post: 10-09-2008, 09:11 AM
    3. Comparison Chart of All types of Linear Rails and Motion???
      By douglasco in forum General Waterjet
      Last Post: 07-19-2008, 08:19 PM
    4. What type of round stock linear rails
      By Tomthegiant in forum Linear and Rotary Motion
      Last Post: 02-04-2008, 12:01 PM
    5. round rod for linear motion?
      By tigpro in forum Linear and Rotary Motion
      Last Post: 08-15-2005, 11:08 AM
