Page 1 of 4 1234 LastLast
Results 1 to 12 of 47
Thread: My new (desktop) cnc router 'Hephaistos' almost complete...
    Registered effimos's Avatar
    Feb 2012
    Belgium
    Smile My new (desktop) cnc router 'Hephaistos' almost complete...
    this is my first ever made cnc router.
    i always wanted to make one but never had the courage to finally begin building one. now i have/am making one
    here are the pictures of the initial design and some specs:
    -> note that the base of the initial design will be shorter when i actually make the router, i wanted to put the controller in the base of the router but decided afterwards to put it in a seperate box.
    Type:
    fixed gantry
    size: 48cm x 62cm x 37cm
    cutting surface: 22cm x 44cm
    (and the Z-axis can move 8cm up from the cutting surface)
    materials base: waterproof multiplex
    materials Z-axis: PVC 10mm
    controller: Tochiba TB6560
    Motors: Nema 23
    router: Dremel
    Attached Thumbnails Attached Thumbnails My new (desktop) cnc router 'Hephaistos' almost complete...-cnc_router.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-aanzichten.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-cnc_router_-_3d_z-_samenstelling.jpg
    Feb 2012
    Belgium
    Lightbulb production of the router
    here are some Photos of the production process:
    Attached Thumbnails Attached Thumbnails My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01052.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01053.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01046.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01054.jpg
    My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01056.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01057.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01058.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01060.jpg
    My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01061.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01063.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01064.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01065.jpg
    Feb 2012
    Belgium
    Lightbulb waiting for my bearings, here's an update..
    i'm still waiting for my bearings to arrive so here's an update.
    the machine is almost complete, just have to add the bearings and putting the Z-axis and the cutting table on. the controller is also ready.
    Attached Thumbnails Attached Thumbnails My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01109.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01112.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01113.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01114.jpg
    My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01110.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01111.jpg
    Feb 2012
    Belgium
    handy!
    saw these cable label ty-wraps and got the idea to also use them for cable managing. when drilling 2 holes in the 'label' you can screw these on your machine and strap your cables on like you can see in the picture(s):
    Attached Thumbnails Attached Thumbnails My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01115.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01116.jpg   My new (desktop) cnc router 'Hephaistos' almost complete...-dsc01117.jpg
    Nov 2007
    looks very well executed. Are you planning on using all thread for your leadscrews?
    Jan 2008
    canada
    Looks good! And good call on the name too!
    Registered DonFrambach's Avatar
    Nov 2006
    Very nice! Thanks for sharing your pics. Great idea for cable management!
    Feb 2012
    Belgium
    Angry goddamnit!!
    goddamnit!!!
    about a week ago i recieved my cnc controller kit from Ebay and it didn't work!
    even worse, the board fried up after 10 minutes....
    ok, no problem i thought because the seller agreed to send me a new one for free as it could be a production failure of the board.
    today i recieved that new board, connected it and only 2 out of 3 axis outputs worked, the other motor just turned VERRY slowly while twitching :s
    and after 5-10 minutes the board fried up AGAIN!!!!!
    what the hell is wrong with these boards!?!?!?
    ps: i checked everything 3-4 times before testing it, software settings & hardware connections :O
    Attached Thumbnails Attached Thumbnails My new (desktop) cnc router 'Hephaistos' almost complete...-imag0191.jpg
    Registered LouF's Avatar
    Sep 2011
    Maybe get a refund and try a different vendor..
    Lou
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
    Jan 2008
    canada
    Are those chips heat sunk in any way? I see washer outlines, but no threads.
    I feel your pain; can you get a gecko ? Their products are stable and well supported at the source and on the fora.
    Sep 2011
    That is what I run Gecko G540..
    G540 4-Axis Motor Control
    Lou
    Feb 2012
    Belgium
    Quote Originally Posted by PaulRowntree View Post
    yes, there's a cooling-plate atatched to them with a fan on top, i just had removed it because i wanted to replace one of the exploded chips with a not-exploded one from my other controller just to test it.
    and a Geko is more expensive. i made this for a school project so i had a small budget where i canot get over. these boards were 85$ while a Geko G540 is 300$ and i cant spent this kind of money anymore.
  • Page 1 of 4 1234 LastLast
    1. Complete Newbie, desktop CNC questions
      By Andy Jarosz in forum CNCzone Club House
      Last Post: 06-28-2010, 06:18 PM
    2. My desktop cnc router
      By fahque99 in forum DIY CNC Router Table Machines
      Last Post: 01-08-2010, 07:00 PM
    3. Looking to buy, or build a desktop CNC router.
      By Mattdg67 in forum DIY CNC Router Table Machines
      Last Post: 02-07-2009, 01:18 AM
    4. Is there an Aussie Desktop CNC Router available?
      By Dr Zoot in forum Australia, New Zealand Club house
      Last Post: 07-14-2008, 01:32 AM
    5. Pro Desktop Router Drawing
      By 50062040 in forum Open Source CNC Machine Designs
      Last Post: 04-18-2008, 02:28 AM
