Results 1 to 6 of 6
Thread: CNC ROUTER HELP
    Oct 2010
    CNC ROUTER HELP
    I could use some assistance from experianced cnc router users. I recently purchased a 4X4 cnc router system from a canadian builder, the machine looks well built, but I am getting inconsistent cuts.
    For my latest project, I used corel to draw my speaker baffle, then copy and paste to make a second one, next I imported the file into cut 2D, and saved as a .txt file and sent to the router. The router uses Mach 3.
    When I made the cuts, I believe the speed was 40 and plunge 30, cutting depth .125/ . When I lay the 2 pieces together they are not identical, so I looked at the drawings , and they appear perfect.
    So far I have checked belt tension, cleaned the slides and checked for play, so far everything appears ok, but still getting poor cuts.
    Any help is appreciated, Dave
    Jan 2008
    canada
    Quote Originally Posted by Gothover View Post
    Can you provide any more detail about how the 'A' and 'B' pieces differ, and by how much? If you repeat the cut of the two pieces, are the two 'A' components identical, the two 'B' components, or are all four pieces different?
    Nov 2007
    Are you missing steps? Perhaps a issue with the computer running mach3?
    Registered Walky's Avatar
    Jul 2009
    Chile
    Maybe it's out of square, cut a square and check if both diagonals are the same.
    Registered bonmotwang's Avatar
    Feb 2011
    You did mentioned it is not Chinese, but who is the builder? :-D
    Apr 2009
    Checked motor couplings? Maybe rails are out of alignment causing some binding? Pics of the cut pieces might help.
    1. Newbie- Buying a new 48x48 Art-Router 4 Axis CNC Router
      By Stoch in forum Open Source CNC Machine Designs
      Last Post: 12-17-2010, 07:08 AM
    2. Need Help!- with a Precix Table Router with Perske router
      By SignShop Grunt in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-08-2010, 05:08 PM
    3. Router Using 3/4" MDF (first router build)
      By eguy208 in forum CNC Wood Router Project Log
      Last Post: 04-11-2008, 11:33 AM
    4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
      By Apples in forum DIY CNC Router Table Machines
      Last Post: 09-23-2006, 04:33 PM
    5. Surfcam PP for Isel router / Precix router
      By IvanTochev in forum Post Processor Files
      Last Post: 05-12-2004, 01:27 PM
