Results 1 to 5 of 5
Thread: How do you attach linear motion slides to aluminum extrusion?
    Feb 2012
    I was planning on using fractional aluminum extrusions with these:
    Glacern CNC 20mm 49" SBR Linear Motion Guides Slides | eBay
    But the mounting hole spacing doesn't come close to matching up with these, nor on the metric extrusions...
    So how do you pro's mount these??? (on the sides)
    dinkyguitar
    Registered DonFrambach's Avatar
    Nov 2006
    I'm certainly no "pro" but I mounted my Glacern 20mm supported rail to 8020 extrusions my making a mounting plate from 3/8" cold rolled steel. I mounted the steel to the extrusions and then drilled and tapped the cold rolled steel to bolt the rails to the steel.
    JerryBurks in his bamboo build simply drilled and tapped the aluminum.
    Here's a link to each of our builds:
    http://www.cnczone.com/forums/cnc_wo...w_machine.html
    http://www.cnczone.com/forums/diy-cn...ry_router.html
    Registered FandZ's Avatar
    Oct 2008
    They should line up on the side of these... 670017, 30 X 60B T-Slotted Extrusion, Metric Extrusions (30B Series) - automation products from Automation 4 Less
    They also should work with 80/20 metric 3060 unless I'm missing something.
    Apr 2009
    They should fit any base 30 extrusions... They are strongest oriented in the way in the pictures...
    Aug 2008
    Yep, any base 30 extrusion, or the 6 series extrusion from Misumi also has the 30mm hole spacing that the rails use.
    1. How to attach metric ball rails to aluminum extrusion?
      By dinkyguitar in forum DIY CNC Router Table Machines
      Last Post: 02-28-2012, 11:56 PM
    2. CNC 20mm 29" Linear Motion Guides Slides
      By Machinaria in forum EBAY ADS
      Last Post: 11-30-2010, 07:19 PM
    3. Anyone used Polythene pad slides for T slot extrusion
      By cweeks in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-10-2009, 07:29 AM
    4. CNCRouterParts -- New linear motion system for use with 8020 extrusion.
      By ahren in forum Product and Manufacturer Announcements
      Last Post: 02-27-2009, 12:36 PM
    5. All aluminum Router-Ballscrews, extrusions, linear slides
      By LazyMan in forum CNC Wood Router Project Log
      Last Post: 01-20-2008, 04:09 PM
