Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: Small Fixed Gantry Design
    Jul 2011
    Smile Small Fixed Gantry Design
    Hey guys,
    I have been silently looking over many of the amazing builds on the website and have gathered a wealth of knowledge thanks to you guys!
    A bit about myself, I am 16 years old and for my senior project for high school, I plan on building a small CNC router.
    The CNC router will be used for; PCB's, wood work, plastics and (hopefully) Aluminium.
    The main base frame is made from 40x40 and 40x80 extrusion and the Z axis is made of 12mm aluminium. The side plate are made from 12mm steel plate.
    The linear rails that are going to be used are the 16mm supported rail type that you can get from ebay.
    The proposed working area is 300x200mm with 110mm z.
    Attached is my design so far and was just looking for you guys opinions and improvements!
    Praneet
    Attached Thumbnails Attached Thumbnails Small Fixed Gantry Design-cnca.jpg   Small Fixed Gantry Design-cncb.jpg   Small Fixed Gantry Design-cncc.jpg   Small Fixed Gantry Design-cncd.jpg
    Apr 2009
    Nice and clean design, though I think you might be better served with at least 20mm side plate...
    Aug 2008
    Just a bit of advice,
    Go for thicker gantry uprights.. go for 20mm rails instead of the 16mm, and use extrusion that is compatible with the rails hole spacing (30mm), it will save you a ton of work.
    Also, if possible drive your Z from the center instead of the side, less chance of binding.
    Just my 2c.
    Looks good though, keep it up!
    Registered DonFrambach's Avatar
    Nov 2006
    Looking very good. I agree with 20mm rails, thicker sideplates, and a center driven "z" axis. I would also suggest that you consider adding corner braces where possible to stiffen your frame. Please keep posting!
    Aug 2008
    Oh, one more thing, remove the center support between your Gantry Y Rails, you will want to mount the ballscrew/lead screw in this space most likely, you can replace the center support with a solid plate across the entire back of the gantry to maintain support.
    Also, if your budget allows, try to mount the supported rails for your Y gantry on the top and bottom of the gantry instead of the front like it is now. The supported rails work better this way, having them on the front will cause the bearings to push and pull away from the rails when your cutting in the X direction.
    Dec 2010
    croatia
    looks good. man, if i had access to any kind of extrusions, i wouldn't give mdf a second thought. just pay attention to accuracy, and squareness, and you're on to something.
    good luck!
    Registered Drools's Avatar
    Feb 2009
    I really like this design, it is very similar to what has been keeping me awake at night.
    12mm vs 20mm steel plate for the gantry uprights... Will 12mm or (1/2") steel plate really flex that much?
    I was thinking about the height of the Y (gantry axis) do you need it to be as high as the illustrations are showing? The distance from the bottom of the Y axis to the table top looks to be large for doing PCB/plastic/Aluminum.
    Thank You.
    Jul 2011
    Thanks guys for all the recommendations
    I have redesigned my y axis to incorporate the rails on the top and bottom of the gantry, instead of the front.
    Also will the center drive on the z axis make much difference? If I do decide to incorporate the lead screw in the center i will lose about 50mm of y travel and i would like to avoid this as much as possible.
    As for the 16mm rails; this is all my budget can allow as the 20mm rails are much more expensive if i go out of the ebay listing that has 200,300 and 450mm rails.
    And as for using 30 series profile instead of the 40 so that I can bolt the rails directly on the profile is a great idea, however the 30 series profile that is available to me is a "light series" and has no where near as much mass as the 40 series.
    I plan to run the y axis leadscrew behind the rails so that it will stay out of the way and be less prone to dust.
    Another question:
    As drools has said will the 12mm (or 1/2in) flex that much?
    thanks
    Praneet
    Attached Thumbnails Attached Thumbnails Small Fixed Gantry Design-cnc_rev_2a.jpg   Small Fixed Gantry Design-cnc_rev_2b.jpg   Small Fixed Gantry Design-cnc_rev_2c.jpg   Small Fixed Gantry Design-cnc_rev_2d.jpg
    Apr 2010
    Keep up the good work! I would agree with the 20mm side plates, I think that is the weak point in your system. I would also concur with using the SBR 20 rails instead of the 16's. It is really not much more money, and I think for your application they would work better.
    The last thing I would add, is I would use a single extrusion for your gantry instead of two separated. Mathematically you get so much more strength, plus I think it would be easier to align, assemble, fabricate, etc.
    In the end though you need to build it the way YOU want to build it. It will be a fantastic learning experience for you- mine sure was. Then you will unquestionably want to build another better one. Taking everyone's advice without question is just as foolish as taking no ones advice. You'll do fine.
    I don't think you will have any problem cutting aluminum in light passes. Keep it up! I will be follow this.
    Nov 2006
    Quote Originally Posted by crane550 View Post
    In the end though you need to build it the way YOU want to build it. . . . Taking everyone's advice without question is just as foolish as taking no ones advice.
    Totally agree. This will be YOUR project. Good luck! Please post your progess.
    Apr 2007
    Quote Originally Posted by praneetn7 View Post
    Another question:
    thanks
    Praneet
    If you find too much flex under cutting loads you can add triangular side plates or rectangular strips on each side to stiffen it after it is in operation.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Oct 2005
    Half inch thick steel sideplates in that size are not going to flex much at all, the machine will be a lot more rigid than most people's.
    One thing I would suggest is to check all the suppliers for the exact lengths that the linear bearing rails (and ballscrews) come in, and adjust the machine dimensions to suit those so you don't have to try to cut the rails or waste inches with rails that are a tiny bit short etc.
    And it also looks as though you could extend the length of the machine a bit without increasing the cost much. This again depends on the standard lengths for rails and ballscrews, but it does look like you could make the machine slightly longer (10%? 25%?) with very little added cost (as the gantry remains the same) so it's worth looking into.
  • Page 1 of 3 123 LastLast
    1. Fixed Gantry - Trying again
      By harryn in forum CNC Wood Router Project Log
      Last Post: 04-07-2013, 07:37 PM
    2. New Machine Build- Fixed gantry router
      By KTP in forum DIY CNC Router Table Machines
      Last Post: 04-17-2011, 06:44 PM
    3. New Machine Build- 8020 Fixed Gantry Design
      By jupdyke in forum DIY CNC Router Table Machines
      Last Post: 12-30-2010, 05:48 AM
    4. fixed gantry
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 01-29-2009, 05:20 PM
    5. Fixed Gantry
      By Auzze in forum DIY CNC Router Table Machines
      Last Post: 07-25-2004, 03:34 AM
