Best belt drive ever! (If I do say so myself) - CNCzone.com-The Largest Machinist Community on the net!
I've built a prototype with a stepper (haven't tried it yet), and someone else has one working. You're tank tread idea is discussed there as well.
http://www.cnczone.com/forums/diy-cn...ock_solid.html
Try Modern Linear or Superior Bearing. Don't be surprised if the shipping is $20 or more, so order everything at once.3) Speaking of those grooved bearings...
I started off looking at ideas with the skate bearings and angle iron, then grooved bearings and the thin edge of angle iron, CRP's guides, and so on, but I think I really like the grooved bearings and the actual rails they are DESIGNED to roll on. Can anyone point me at the best price/source? I get a bit annoyed at looking at catalogs with no prices in them. Makes it hard to budget.
[quote]
4) Router-mount overhang.
One of the earliest sites I visited was cncroutersource.com, which had a lot of really good information, but alas has a LOT of incomplete pages. But one that was there discussed moment arms in your typical machine. Since I've been planning to build the machine from wood, primarily Russian Birch Ply, I was very concerned with rigidity. I could see LONG moment arms caused by both the router hanging way out there at the end of an L-shaped Z-axis carrier, suspended under a very high Y-axis in the vertical plane.
I wanted to counter this by first, making the "wheelbase" of the x-axis carriage very long (almost 2' in some variants I've been contemplating), and second by having the Y-axis be in a horizontal plane, with the Z-axis carrier being between the rails. it would REALLY shorten up that moment arm.
But I can see some big problems with this approach, including that I'd basically be making TWO y-axis gantries to support a box in the middle, doubling my weight and the number of bearings and length of rail. I've considered making what I was calling the "front rail" considerably less substantial, using it to counter twisting moment, but not really carrying a lot of weight.
The primary mission of this machine is cutting shapes out of plywood, so the clearance will stay pretty low, also shortening the moment arm. But am I obsessing unnecessarily?
[quote/]
I've got a pretty compact design made from baltic birch ply.
Z AXIS - Moving bearings or moving rails ?
But both the Shopbot and Mechmate use the double gantry approach, with the spindle in the middle.
[quote]
5) And on the topic of the Y-axis...
Triangular torsion boxes. Not much to say there, but that's what I'm picturing. A vertical member for the rails to be attached to, a horizontal member for rigidity, a bunch of triangular webs, and another piece of wood closing up the back.[quote/]
Harder to build, harder to mount??
LinkBack URL
About LinkBacks
