Results 1 to 2 of 2
Thread: g540 and nema 23 connection
    McX
    McX is offline
    Jan 2011
    United Kingdom
    Hi all. I'm building 800x800x200mm cnc table. After readin this forum I have all electronic stuff on table and i need to get it work. Electronis=cs is not my strongest point, so i need dumb proof manuals for that job. i USE G540 GECKO, NEMA 23 8cord and mach3.
    1. Can i find step by step nema 23 manual to connect it to g540\? Like yellow pin1, red pin2 etc. One drawing with resistor in it confusing me.
    2. What 8 cord wires are better to use to extend way from stepper to board? Can I use PC com cables (cords looks very tiny to me)
    3. I use 2 steppers to move X axis. What is the best solution to pair two steppers with my stuff? Pair in mach3? Modify serial cable? any other?
    Oct 2004
    Quote Originally Posted by McX View Post
    1. You should be able to find all the g540 information on the GeckoDrive website
    2. You should only need four leads in the motor cable. Pairs of the 8 leads from the motor are tied together to give 4 leads to the drive. Phone wire should work.
    3. Slave the motors together in Mach3.
    Chris
  1. G540,620 oz nema 23, what power supply and winding?
    By umustsurf in forum Gecko Drives
    Last Post: 09-16-2011, 01:50 PM
  2. NEMA 23 with a G540
    By jallenmorris in forum CNCzone Club House
    Last Post: 05-27-2011, 12:58 PM
  3. Need Help!- G540 and Nema 17
    By Walky in forum Gecko Drives
    Last Post: 01-18-2011, 10:06 AM
  4. Quick G540 connection protection question.
    By Propaganda in forum Gecko Drives
    Last Post: 02-15-2010, 03:31 PM
  5. nema 34 1600 oz or nema 42 3200 oz?
    By 15mgtar in forum Stepper Motors and Drives
    Last Post: 07-27-2009, 06:53 PM
