Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Cutting Aluminium ecologically
    Mar 2010
    none
    Hi All,
    I am building a cnc tool. It include Chinese spindle (2.2 kW) min speed of 8000RPM.
    I would like to millaluminium. I read that 8000RPM is too high and I will have to use coolant at this RPM.
    I am really concerned about health issues therefor I am trying to avoid the use of cutting oil, which I think is not healthy.
    I thought to use pure water as coolant (Since water is not an issue for aluminium). Does any one use only pure water as coolant?
    Does anyone familiar with ecologically coolant for aluminium? Or other healthy technique to mill aluminium without cutting oil?
    Regards,
    Amir
    Feb 2012
    England
    Are you drinking it,Amir?
    Since you have a 2.2kw spindle are you not using a VFD with it? this should get the motor right down speed wise.
    May 2005
    We use just plain tap water in our horizontal bandsaw when cutting steel and aluminum.
    After we are done, we spray the vise and table with WD40 so as not to encourage rust.
    May 2005
    Also, you should note that many coolants are vegetable based and non toxic
    Mar 2010
    none
    Quote Originally Posted by HorridHenry View Post
    not drinking it () however there are steam and smoke from it.
    I do have VFD (x200 hitachi) and I can control the speed however the spec of the spindle is 8k -24k RPM so don't know the effect if i going bellow it.
    Mar 2010
    none
    Quote Originally Posted by vid1900 View Post
    10x. Maybe I will try to spray only water and hopefully it will be enough.
    Do you have experience with the vegetable coolants? Can you recommend one?
    BTW does your machine is sealed except the table and spindle?
    Feb 2012
    England
    Don't understand? that VFD has a digital readout for its speed.
    google speeds for cutting metal and this will give you an basic idea as to what speed you need to set the spindle to.
    Not the best link to direct you to but if your maths are good the equations are there.
    http://en.wikipedia.org/wiki/Speeds_and_feeds
    May 2003
    91% isopropyl alcohol works for me.
    Mar 2010
    none
    Speeds and feeds - Wikipedia, the free encyclopedia
    I don't see specific speed. However, what I mean is the following - if I will go bellow 8000RPM maybe the force that the spindle induce for cut will be lower.
    Thanks for the link
    Apr 2009
    I usually cut at 12k-13krpm, but at 60-70ipm and .125" doc for pocketing, and .063" profiling on a .250 endmill. As long as your setup is ridgid enough to take it. I find aluminum machines well as faster rpm as long as you match the speed to get the right sized chips.
    I was using WD-40 and such for aluminum, but I found a better, cheaper solution.... PAM High Heat cooking spray! It even smells like breakfast! Datron machines use methanol for coolant.
    Jul 2007
    Use smaller cutters they need more RPM to get the required SFM. 1/4 inch and smaller HSS or carbide should work. Take very light cuts and you should be fine.
    bob
    Mar 2010
    none
    Quote Originally Posted by rowbare View Post
    bob
    I am not sure I understand.
    1/4 inch hss without coolant @ 8000RPM should be OK? 0.04" depth is OK?
    Thanks anyway for the info.
  • Page 1 of 3 123 LastLast
    1. How Does CNC Routing Compare to Traditional Powertools Ecologically?
      By marklavin in forum Environmental & Alternate Energy
      Last Post: 11-04-2011, 08:51 PM
    2. Cutting Aluminium
      By djh82uk in forum Benchtop Machines
      Last Post: 06-26-2010, 06:48 PM
    3. Newbie- Help cutting aluminium
      By Codeman in forum General Metalwork Discussion
      Last Post: 04-10-2010, 06:49 PM
    4. Need A Quote- For aluminium cutting
      By btoes in forum Employment Opportunity
      Last Post: 04-15-2009, 06:31 AM
    5. Cutting Aluminium
      By ninewgt in forum General Metal Working Machines
      Last Post: 07-29-2003, 01:31 PM
