Results 1 to 8 of 8
Thread: Tap making
    Jul 2010
    Tap making
    As many of us know, screws from different makers will vary slightly...
    as there are no 'standards' for multi-start screws. A nut from one may
    or may not work with a screw from a different maker.
    And often, someone may not even know who makes the screw, or
    where to locate the 'right nut'.
    So we have to make taps sometimes.
    I have to make them from time to time, so I finally tried to come up with
    a predictable and consistent technique. It works Great....but it needs a mill,
    and a lathe is also very helpful.
    Basically....
    I used a ball mill.
    Lock the acme scrap in the vise.
    Cut a single fairly groove offset toward the cutting edge by about .015
    Dull the non-cutting edge with a file...(I used a diamond file...carefully)
    I tried this about 3 times to be sure it does it consistently. Mine is a 3/8"
    acme 2 start, but the technique should work on any size with few tries
    at it.
    The single groove working so well really surprised me. I expected to groove
    the other side, but it didn't need it.
    Pictures coming up....
    John
    Jul 2010
    I made a little strip of aluminum so the acme would sit up
    near the top of the vise so I could watch progress....
    I locked the acme between a softer piece of aluminum so as to not
    damage the threads. I could've used a second aluminum bar, but I
    know how tight I can lock it in the vise without problems....
    So it all fits well and looks secure enough.....
    Next, the taper needs to be done before the groove milling. I used
    2.5" as the taper length. I just used some rough files in the lathe to
    do the taper. That was quick & easy. Then polishing it up a bit....
    More pictures coming up.....
    Jul 2010
    It worked out that a 1/4" ball mill was just the right thing for
    the 3/8" acme....
    Cut a little bit at a time. Not too deep per pass....
    The tapered end will spring a bit, so several passes are needed until
    the groove looks good on the tap end.
    Dec 2008
    Great info, Thanks John I think I need to head to the shop and try this.
    Don
    Jul 2010
    Presto!...A nice deep grooved tap that works excellent for making
    plastic nuts....
    Naturally, your mileage will vary. But I was able to make 3 out of 3
    tries at it all work....once I figured out a procedural way of doing it.
    The old way was a huge PITA using cut-off wheels and grinder bits.
    Only problem with this is the mill is pretty much needed. But it's quick,
    easy and predictable.
    John
    Jul 2010
    Quote Originally Posted by atwooddon View Post
    Don
    I thought I'd need grooves on both sides, but it
    works amazingly well and smooth with just the one....
    An old drill chuck is the thing to hold it. Cutting the ends square like
    on a real tap will weaken the soft steel...besides just being more trouble
    than it's worth...
    From past experience with un-hardened homemade taps....they're
    good for hundreds of delrin nuts.
    John
    Nov 2007
    Thanks for taking the time to share. A mill and lathe are on my wish list.
    May 2010
    I just got a Mill. and have lots of delrin and some scrap 1/2-10 5 start, and a 1/4" ball mill on the way. Guess what Ill be doing this weekend. Ill post up some results
    1. Making a Z gib for X3
      By binfordw in forum Benchtop Machines
      Last Post: 08-24-2010, 12:07 AM
    2. R/C making
      By MBG in forum CNCzone Club House
      Last Post: 02-15-2010, 10:55 AM
    3. Making a CMM
      By Fish in forum General Metal Working Machines
      Last Post: 09-12-2008, 12:13 PM
    4. jig making
      By DerHammer in forum General Metalwork Discussion
      Last Post: 11-19-2007, 12:29 AM
    5. making an arc
      By keebler303 in forum Bridgeport and Hardinge Mills
      Last Post: 10-15-2006, 02:40 PM
