Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Bowed Table Problem
    Registered BanduraMaker's Avatar
    Dec 2010
    Bowed Table Problem
    My machine is made with 8080 extrusions for the long axis. One of the "features" of 8080 extrusion is something called the "Drop Lock" which can be seen here: 80/20 Inc. - The Industrial Erector Set?
    The problem I'm having is that when I bolt down my t-slot extrusion table to my 8020 extrusions, the middle of my table raises about .008 and the ends drop about .003 for a total "bow" of the middle being about .010 higher than the ends. This happens with just the smallest amount of pressure at the ends. I Didn't measure but it's probably even worse when both screws at each end are tightened down. I'm thinking that this is due to the drop lock feature.
    I've checked the table extrusion and it's very flat when it's not being bolted down at the ends. just barely tightening it down to the extrusions it's still flat. By barely, I mean when you take up the slack and the screw just touches the metal. Anything beyond that (like an 1/8th turn) and the middle starts to bow. when the middle is at +.008", the screws are still loose enough to move the table top easily.
    This is a problem. Any suggestions on what could be done to remedy this?
    Attached Thumbnails Attached Thumbnails Bowed Table Problem-bowed_table1.jpg   Bowed Table Problem-bowed_table2.jpg   Bowed Table Problem-bowed_table3.jpg   Bowed Table Problem-bowed_table4.jpg
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Apr 2009
    Quote Originally Posted by BanduraMaker View Post
    I've contemplated this many times, and is the reason I opted to use mic-6 for the table, and add t-track to that. Also, I think the t-table squeezes somewhat, twisting the rest of the extrusion. I think what you CAN do is bore through your long rails to make access holes, and bolt
    the t-table from the bottom.
    The other things you can do? add a couple more 8080 longwise to attach the t-table to, or simply affix a spoilboard and level that...
    Company Representative gio666's Avatar
    May 2008
    Blog Entries
    1
    The problem is the 8080 profiles are not prefect flat , and bow in a little on the T slot ends to help lock stuff together and lower vibration. i found this way a lot better to mount top
    XZero CNC
    May 2008
    Blog Entries
    1
    XZero CNC
    Dec 2010
    Well, I was hoping for something easier but I guess that's the way I'll have to go. Unfortunately it means re-machining my table extrusions but oh well.
    George, What size angle is that?
    Louie, I've been thinking about using MIC6 for a table top for a while but the thought of all that drilling and taping isn't that appealing. I could see doing that upgrade down the road when I have a better grip on exactly how I'm going to be running my machine.
    -Andy B.
    Dec 2010
    I think for now I'm going to go the angle route for mounting the table.
    In any case, I'm going to use 1.5" angle and I'm trying to decide between 1/8" hot rolled steel and 1/4" aluminum.
    The aluminum sure would be easier to tap but the steel would hold longer.
    Any thoughts on whether one might be flatter than the other?
    -Andy B.
    Mar 2003
    Shelby Twp, MI....USA
    I have some 1/4" x 1-1/4" aluminum angle and it's not 90°. It's off about 1/2-1°.
    Dec 2010
    eeeenteresting. I found a short chunk of 2"x2" .250 angle aluminum in the basement and it's quite flat and seems to be dead nuts 90 degrees. I checked it with a square and a digital angle finder.
    I'm leaning toward the Al route just because it will be much easier to drill and tap. Theoretically it should expand at the same rate as my extrusions too although I do have 20mm steel rails bolted to it so I guess that's somewhat irrelevant.
    -Andy B.
    Mar 2003
    How much temperature change do you get in your basement?
    Dec 2010
    I don't know. It seems that my ears and face get all of sudden hot from time to time when using my machine so it seems that there are wild temperature swings in the basement that seem to coincide with breaking bits and ruining parts....weird!
    -Andy B.
    Dec 2010
    Quote Originally Posted by ger21 View Post
    Ger,
    Thanks for bringing this up. I stopped at Metal Mart today to pick up the angles and it wasn't until I went to the architectural Al that I found the square stuff.
    Glad I brought my square!
    -Andy B.
    Registered JerryBurks's Avatar
    Aug 2011
    Maybe I don't understand correctly how the T-slot profiles are installed....but it looks like they are pretty much hanging free over the x-screw for the entire width?
    If that is the case I would be concerned about the flex of these slats. You can have the most rigid gantry in the world but if the table itself gives under weight, clamp and machining force that is no good. The table on my old shark pro machine was made from 3/4" thick extrusions, 30" free hanging, and it contributed about as much to the horrible flex as the flimsy HDPE gantry. That is why I went with 1545 size 80/20 extrusions for my bamboo machine table and these are bolted flat to a solid plywood torsion box (96 bolts M8). Maybe that was a bit overkill, though
  • Page 1 of 2 12 LastLast
    1. rotary table problem video
      By ceramdent in forum Linear and Rotary Motion
      Last Post: 12-14-2011, 03:43 PM
    2. Tormach Table Problem
      By twocik in forum Tormach Personal CNC Mill
      Last Post: 06-21-2010, 10:04 PM
    3. Routech 250 Twin Table problem
      By Travisty in forum Commercial CNC Wood Routers
      Last Post: 10-28-2009, 01:40 PM
    4. Table display problem
      By SScnc in forum Mach Mill
      Last Post: 08-04-2008, 01:44 PM
    5. table tilting problem
      By ataxy in forum Benchtop Machines
      Last Post: 01-27-2008, 02:44 AM
