Results 1 to 4 of 4
Thread: Fix it! (Moving to fixed gantry)
    Jan 2008
    Hi all. I built a moving gantry router primarily out of MDF over the past 6 months. My own design, which was probably a bit ambitious. Now I am left with a machine that works... but is not square, nor rigid.
    Parts I have:
    16mm supported rails: 1100mm, 600mm, 300mm
    1605 Ballscrews: 1100mm, 600mm, 300mm
    Chinese 1.5kw spindle + VFD
    Gantry bridge: 80x80mm aluminium extrusion 610mm long.
    My concept is fairly simple:
    The 1100mm rails bolt straight on to 30x60mm extrusion with 2 (or 3) cross beams.
    Then some short length of 30x60 stick out. On to these bolt 60x60mm gantry uprights.
    The extrusion will be joined by bolt in slot into tapped end + some corner brackets.
    The gantry beam is then attached these with a bracket (not pictured) - this is the main problem with the design, obviously not as strong as gantry beam sitting directly on the uprights. However, unless I want to get rid the $50 piece of metal I have all set up with rails and replace it with a longer piece (which I'd do from 60x60, therefore need nuts etc adding to the $$$) then I'm stuck with this.
    Also not pictured is bracing for the uprights in the X axis plane. I picture that this can be done very cheaply with sheet bolted to the outside of the uprights (triangle shape) with a free edge 'resting' on the table holding the machine.
    Thoughts?
    Load of crap?
    Apr 2009
    Quote Originally Posted by pippin88 View Post
    Parts I have:
    Thoughts?
    Load of crap?
    Seems like you can make your table a lot narrower, since your gantry travel would be the length of the rail minus the width of your carriage? Would make you gantry stronger.
    Mar 2003
    Shelby Twp, MI....USA
    Thoughts?
    Load of crap?
    I don't think that the triangles resting on the table will increase rigidity at all. They need to be fastened to the tubes under the table.
    Jan 2008
    Quote Originally Posted by louieatienza View Post
    louie: My lower Y rail runs on the underneath of the gantry beam. This means I can't get the uprights under the (current) beam. Changing the work table size won't change that unfortunately.
    Quote Originally Posted by ger21 View Post
    Gerry: I should have been clearer, the braces would rest on the benchtop, not the work table. I'll CAD it up tonight.
  1. Fixed vs Moving gantry recommendations
    By aarongough in forum DIY CNC Router Table Machines
    Last Post: 07-04-2011, 02:08 AM
  2. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 02:48 PM
  3. Moving table fixed gantry build
    By judleroy in forum DIY CNC Router Table Machines
    Last Post: 12-14-2010, 11:11 PM
  4. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-27-2007, 09:48 PM
  5. Moving or fixed Gantry ??
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 02-21-2005, 11:54 AM
