Results 1 to 3 of 3
Thread: best ways to atatch skate bearing angle trucks ?
    Aug 2011
    UK
    I cut some angle iron to 7" and drilled the holes 1/2" in for the bolts for the skate bearings. spaced with nuts, and cut to length after with the angle grinder.
    so, what are the tried and trusted ways for attaching these to the wooden sides for the Z assy ?
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Mar 2003
    Shelby Twp, MI....USA
    Route some slots to support them, and bolt through the angle. The 4th pic here shows mine.
    Another First Router
    Aug 2011
    UK
    Thanks Gerry
    that's quite neat
    I'd seen various options along that theme on some builds here. That shows it quite clearly !
    As I'm using steel angle, I'm considering tack welding some threaded rod to the inside, instead of drilling through, and clearancing for the bolt head.
    the slots look easy to do on the TS too
    Cheers
    Rich
  1. Newbie- Can UHMW-PE be used for bearing trucks?
    By Go-Go-Legoman in forum DIY CNC Router Table Machines
    Last Post: 12-29-2011, 05:48 PM
  2. Adjusting cncrouterparts bearing trucks
    By tkms002 in forum DIY CNC Router Table Machines
    Last Post: 04-03-2011, 01:00 PM
  3. What size rails for these Bearing trucks
    By planekrazie in forum Linear and Rotary Motion
    Last Post: 09-04-2006, 10:02 PM
  4. New Truck Design - Angle Iron & Skate Bearings
    By datacop in forum Open Source CNC Machine Designs
    Last Post: 07-12-2006, 11:24 AM
  5. Bearing Trucks
    By camcam in forum Linear and Rotary Motion
    Last Post: 06-16-2006, 04:08 AM
