Results 1 to 3 of 3
Thread: DIY clamps for T-slot
    Registered Drools's Avatar
    Feb 2009
    I'm looking for some ideas for clamps that will work with my T-Slots. I would like to make the clamps myself as opposed to purchasing them.
    Thanks for the help.
    Thank You.
    Jan 2006
    A standard clamping set is quite versatile and not worth building yourself.
    Jet Milling Machine Clamping Set, 52-Piece
    If you want a specific type, you can probably just copy the commercial version.
    Matt
    Jun 2010
    MYOG
    Quote Originally Posted by Drools View Post
    I use nuts from an aluminium extrusion supplier or bits of steel strip of the right width, drilled, tapped and cut to the right length.
    I use M6 Allen-head bolts of various lengths and M6 threaded rod.
    I use M6 wing nuts
    I mill out my own clamp bars from 12.7 mm and 15 mm steel bar.
    Of course, you could go to M8 if your T-slots are larger.
    You do NOT need tempered steel fittings if you are not into heavy production. Mild steel holds very well. hey - there are companies selling *aluminium* clamp systems! They work.
    Cheers
  1. Need parts: Gooseneck & Clip on clamps/screw bar clamps, padded
    By LordStDennis in forum RFQ (Request for Quote)
    Last Post: 06-27-2011, 07:07 PM
  2. T slot hold down clamps and cams where to buy?
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 06-15-2011, 01:01 PM
  3. IH mill t-slots and mitee-bite t-slot clamps
    By altaic in forum Industrial Hobbies (Support forum)
    Last Post: 12-24-2008, 01:56 AM
  4. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-09-2008, 10:02 PM
  5. Where to get T-slot clamps?
    By Sporqster in forum Benchtop Machines
    Last Post: 07-12-2005, 12:22 AM
