Page 1 of 3 123 LastLast
Results 1 to 12 of 30
Thread: Finished my new Echain project
    Registered msimpson99's Avatar
    Aug 2010
    I just finished a my Echain for my new build. Its thinner than my last Echain and I cut it out of sintra.
    I added an enlarged the ends to hold connectors
    Here is a little vid of the parts:
    http://www.youtube.com/watch?v=q4REZTbJQZE]Makeing Dragon Cable - YouTube
    Here you can see it in action:
    http://www.youtube.com/watch?v=kbiIKNd-lwk]KRMx02 Dragon Cable - YouTube
    You can download the compleate project and gcode here:
    KRMx01 Dragon Cable Upgrade
    I have a project of a larger cable here:
    Attached Thumbnails Attached Thumbnails Finished my new Echain project-dragoncablesmall.jpg
    Registered DonFrambach's Avatar
    Nov 2006
    Very nice!!!!!!!!!!!!!
    Nov 2011
    Nice one, will definitely be using that on my machine(s). I see you use a product called Sintra, is that a brand name or product type? I can't seem to find Sintra here in Australia.....
    Cheers
    Mar 2003
    Shelby Twp, MI....USA
    Sep 2005
    Nice job!
    Robert
    Oct 2011
    Scotland
    That's a real nice job. And thank you for sharing the design.
    bruce
    Jul 2011
    Oh this is sweet and thanks for the G Code!! I will be making one of these as likely my first project!
    Nov 2011
    Quote Originally Posted by ger21 View Post
    Untitled Document
    I think this is the same as Sintra.
    Plastix - Foamed PVC (Foamex, Forex)
    Thanks Gerry
    The Aussie equivalent certainly looks like Sintra, I'll check that supplier out.
    Cheers
    Bruce
    Dec 2010
    croatia
    this looks great. of course, someone will say that it would be a lot cheaper and simpler just buying the chain, but i say this way is 10 times more fun!
    keep informing us of your work, it all looks great
    Aug 2010
    Quote Originally Posted by lamesh99 View Post
    Dont know about that. I think I have about $50 invested and have an echain that matches my machine perfectly. Goes from one end to the other, not just the moving portion. Its bolts directly to my machine. If it breaks, I can fix it for next to nothing (lots of spare parts)
    Registered HelicopterJohn's Avatar
    Dec 2005
    Seffner, Florida USA
    Inside dimension of channel
    Do you know what the inside dimension of the channel on the larger chain?
    You mentioned that you made one for a larger cable. Did that mean a larger diameter e-chain box or did you mean a longer cable?
    I have a Shopbot that I would like to make some e-chains for.
    Any information would be appreciated.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://www.helicopterjohn.com/
    Aug 2010
    2.76 x 1.6
    You can see it here:
    http://www.youtube.com/watch?v=66RWneaKxQ8]KRMx01 Dragon Cable - YouTube
    Download it here:
  • Page 1 of 3 123 LastLast
    1. DIY flex metal echain
      By mlaws1172 in forum DIY CNC Router Table Machines
      Last Post: 07-24-2009, 03:52 PM
    2. Finished a new project today
      By ger21 in forum WoodWorking
      Last Post: 03-30-2007, 01:14 PM
    3. X2 cnc finished for now
      By hoss2006 in forum Benchtop Machines
      Last Post: 01-12-2007, 05:55 PM
    4. Finished First Project
      By P40Sortie in forum Shopmaster/Shoptask
      Last Post: 06-04-2006, 09:41 AM
    5. Finished project
      Last Post: 10-29-2005, 02:09 AM
