Results 1 to 6 of 6
Thread: On the off-chance I thought up something new..
    Jan 2010
    I've been lurking on here for the past couple years, but finally found an opportunity to buy an FL200 style cnc router locally off Craigslist. As it was already assembled, bolting additions on required buying either 8020 unique parts or coming up with something different.
    To that end, this is what you can do with $0.18 carraige bolts from Lowes:
    On the off-chance I thought up something new..-imag0214.jpg On the off-chance I thought up something new..-imag0217.jpg
    Chop off two side wings, grind off two corners of the square bolt end, insert into 8020 slot and turn to the right. It may not have the full strength of the original, but it's plenty for the small additions I'm working on. (Bit storage, etc)
    Hopefully this is my beginning to giving back.
    Thanks for your shared knowledge all.
    V
    Registered Drools's Avatar
    Feb 2009
    Thanks for the tip!
    It is always nice to have alternatives to add-ons once the machine is assembled. Certainly is less expensive than the 80/20 hardware that does the same thing.
    Thank You.
    Registered CNC Lurker's Avatar
    May 2009
    That's a great idea, thanks for sharing.
    http://paul-flores.com/
    Jan 2008
    canada
    Another option is to drill a hole in the 8020 tracking in an unused area of the material that is large enough to pass the head. This way the head can't slip out if turned.
    Mar 2011
    Quote Originally Posted by PaulRowntree View Post
    I agree. I made a hole drilling jig with extra stuff I had laying around. It works really good too A 3/4 hole saw, scrap piece of plywood, 2 slip nuts and bolts.
    Jan 2010
    That jig is definitely going on my list of projects. This was just for quick, temporary attachments.
    1. Does this have any chance of working?
      By Dman65 in forum DIY CNC Router Table Machines
      Last Post: 08-09-2009, 09:51 PM
    2. Newbie- Any chance?
      By nelZ in forum BobCad-Cam
      Last Post: 12-18-2008, 02:53 PM
    3. Chance to buy '94 Fadal VMC-15 ...
      By kochevnik in forum Fadal
      Last Post: 06-23-2007, 01:39 PM
    4. My chance to mutilate a CNC
      By erebus in forum Joes CNC Model 2006
      Last Post: 05-18-2007, 10:41 PM
    5. looking for chance
      By salem in forum Employment Opportunity
      Last Post: 07-27-2006, 03:10 PM
