Results 1 to 5 of 5
Thread: 4x8 cncroutparts.com design-- solo X drive or dual?
    Jan 2012
    I am new to the whole cnc thing and I wanted to make sure I made the right decision why do I want to have a dual x drive?
    Registered Walky's Avatar
    Jul 2009
    Chile
    It's usually to prevent gantry racking, and to avoid screw whipping if you have a really long X axis with a single leadscrew (the screw can get pretty heavy at those lenghts, too).
    Also, two motors will have more torque than one, and will usually make the X/Y axis easier to square.
    vrf
    vrf is offline
    Sep 2009
    It prevents the gantry from racking back and forth when you have it driven from both sides instead of the middle (which could act as a pivot point).
    Jan 2012
    makes sense lol Thanks guys I will definitely be going with a dual drive nema 23 setup from cncrouterparts
    Registered Woodbutcher-59's Avatar
    Aug 2010
    You won't be sorry with your decision....mine is a bit smaller with dual X drive and it works sweet.
    Check it out here...http://www.cnczone.com/forums/cnc_wo..._steel_al.html
    Good luck with yours...
    Jeff
    "I'm tryin to think but nothin happens" - Curly Howard
    1. vector dual drive?
      By durbinmachine in forum Haas Mills
      Last Post: 11-29-2010, 11:58 AM
    2. Dual drive
      By tux in forum DynaTorch
      Last Post: 08-25-2008, 03:04 AM
    3. Replies: 3
      Last Post: 07-03-2008, 07:57 PM
    4. a dual drive solution
      By WhiteTiger in forum DIY CNC Router Table Machines
      Last Post: 09-25-2006, 08:36 PM
    5. Looking for Han solo
      By cseely in forum General CAM Discussion
      Last Post: 04-18-2006, 03:22 PM
