Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Questions -- Small CNC Router with VERY SMALL Work Area, Ideas?
    Feb 2012
    Hello everyone,
    I'm looking to build a small cnc router to rout lightweight material, mostly wood relief and cutting some light inlay materials.
    The work area will mostly be 2"x2" or so but possibly up to 4"x4". The accuracy and tolerances aren't that strict, a hundredth of a inch in a 2x2 would be acceptable, but more accurate is better of course.
    I've looked around and have done a lot of reading. It seems there's not much about DIY in very small machines. Would a larger machine 12"x12" be able to do this smaller work as effectively?
    I have a machining background, and have done a lot of work with Bridgeport mills, Southbend lathes, etc. I currently have a good lathe, but lack a good mill.
    Thanks for any help you can share.
    Apr 2009
    Quote Originally Posted by Building View Post
    Hello everyone,
    A lot of machines I see with small work envelopes have moving tables. With the right components, and you have the right tools to make them, you should get very good accuracy, way more than .01! Look at some of the moving table builds here, like RomanLini's, PEU's, DonFrambach's, etc... FreshMint is making one now that looks good as well. Check out MicroCarve's machines as well...
    I think you might want to consider a larger working area; why limit yourself to such a small envelope?
    Registered jsheerin's Avatar
    Aug 2008
    Here's a tiny mill: Building a Low-Cost Micro-Milling Machine « « CNCCookbook CNC Blog CNCCookbook CNC Blog
    They achieved 0.00012" accuracy with similar construction techniques to what lots of people use here.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Nov 2007
    As louieatienza has already stated go take a look at microcarve. His offering is an incredible value. It'll cut aluminum easily and has good accuracy.
    Feb 2012
    Thanks for the good ideas.
    Reading and researching options seems somewhat overwhelming; so many variables and possibilities for a good or bad machine.
    Since the work this machine will do will always be one-off items, 4"x4" or smaller, I didn't see a need for a larger machine, but I guess for building purposes it would be better to use more standard lead screw, etc parts.
    I was thinking of a fixed gantry Solsylva. Does anyone have good experience with it? I have the plans for the JGRO movable gantry, but it seems like overkill for what this will be used for.
    I have aluminum, mdf, steel on hand, and MACH3 and Rhino software.
    I've seen some electronic kits with NEMA23 steppers, controllers, and powersupply, that look like they have everything I would need on the electronic side. Any ideas in their selection? Would NEMA23 be fine to use with a small 12"x12" system?
    Thanks for any help you can share. I enjoy this research and new thing.
    Apr 2009
    There are a few builds here of the solsylva 10 x 9 machine. You could probably build it in a weekend, and the parts are mainly cross-cut from stock. I'm sure you could make some parts metal to add ridgidity and mass. Since you're cutting small stuff, you may not neet a lot of speed, and could use single-start ACME screws.
    The more popular kits are from xylotex and hobbycnc. CNC Router parts also sells a Gecko540 kit as well. xylotex is as plug and play as it comes. hobbycnc will require some soldering/assembly.
    Jul 2007
    Given your work envelope, why don't you get a small mill instead? A Taig CNC mill has a 10,000 rpm spindle and will give you a lot more flexibility than most routers. It is easy enough to adapt a higher speed spindle should you need one.
    bob
    Nov 2007
    I think the mill idea is a good/great option if you are sure you will not need more than 4" by 4" of cutting area. I think cost is the factor.
    JGRO is a starters system to get you in the door. The only reason I'm building one is so I can make parts for a better system. As I get further and further with the build I become more aware of it's inadequacies and there are many. For hobby purposes it's good. Cheap, can be constructed with hand tools, most of the build materials can be bought from a local hardware store.
    Any idea of your budget?
    Registered Bob La Londe's Avatar
    Oct 2008
    Nema 23 is a motor frame size. Not a power. There are steppers from 70 oz/in (or smaller) to well over 600 in nema 23. Your design will determine speed and practical holding and moving force. Its my understanding that a stepper moving closer to its slowest stable speed will have a lot more force while moving than one turning near its fastest speed. That being said, there are a lot of pulley driven screws on much larger machines running satisfactorily with 280 oz/in nema 23 steppers.
    I have two machines running Gecko G540 controls and 382 ounce steppers that I am quite happy with for the cost. You might check cncrouterparts for similar package.
    Bob La Londe
    http://www.YumaBassMan.com
    Feb 2012
    I'd like to spend under $1k, and since I have everything I need for the framework is it possible? I have a couple different routers and dremel, also have a large assortment of brackets, bolts, and misc machine parts. Seems I'll need slides, linear bearings, feed screws, motors and electronics.
    I was reading about someone's homebrew machine that was made of 2x4 and all hardware store parts that was keeping decent tolerances, well under .010. He had under $300 in it.
    I'd prefer to spend time and build a strong rigid frame and slides, and have decent feed screws and motors. I'll do some more reading.
    Thanks for the good ideas and please share if you have others.
    Dec 2008
    It has been suggested on this thread previously that you look at the Microcarve systems. He has a unit you can purchase or if you are more interested in a DIY approach, he has published plans for building is MV3 unit. Microcarve has developed a small CNC system over time that has been optimized for rigidity, cost, speed and simplicity. You can buy one of his systems (buying) everything within your budget, or save a few dollars building your own.
    I can almost guarantee you will spend a lot of time debugging a system you design yourself, or adjusting one you build from someone else's plans.
    Below are links to 2 threads here on CNCZone about the Microcarve systems. First is a thread about his units he develops and have for sale.
    http://www.cnczone.com/forums/diy-cn...p_machine.html
    Second is a thread showing plans for the DIY version.
    http://www.cnczone.com/forums/diy-cn...ans_files.html
    Good luck no matter which direction you take.
    Don
    Jan 2009
    SoCal
    I say go for the microcarve, i finished mine about a week ago, small cut area and very solid. The parts for it were easy to make. You can purchase a complete Z axis or parts from microcarve if you need to as well.
  • Page 1 of 2 12 LastLast
    1. Small Run Product-Easy, Low Profit. Ideas?
      By v12lover in forum General Business Practices and Pricing
      Last Post: 04-30-2012, 04:58 PM
    2. Looking for small clamp ideas
      By LockTech in forum General Metalwork Discussion
      Last Post: 11-28-2010, 09:29 PM
    3. Use of CNC Router in small Cabinet work
      By mccafferty in forum WoodWorking
      Last Post: 02-17-2009, 10:16 AM
    4. Newbie- small-scale wood router work
      By GcoderD in forum WoodWorking
      Last Post: 06-27-2008, 09:10 AM
    5. Looking for ideas for a small mill DXF files needed
      By Fixittt in forum Benchtop Machines
      Last Post: 08-21-2007, 01:21 PM
