Results 1 to 3 of 3
Thread: G540 Problems
    Aug 2008
    G540 Problems
    My power flickered a few times and now I have no greens led's on the ports and pins diagnostics page. I thought maybe something happened to my motherboard so I changed it out and still nothing. I have tried it with both the original and special drivers. At first it would make my computer reboot every time the Mach screen started to load. I am past that now but still no control. Any ideas?
    Jimmy
    Mar 2010
    Is the G540 alive? If you turn off the charge pump and enable the E-Stop, do you get a green light on the Gecko?
    You can check with a volt meter to see if the signal is getting onto the LPT port pins.
    Are you sure your LPT port is set correctly for Mach?
    Aug 2008
    I finally got it all working. Had to try another motherboard and reinstall Mach. Weird though, 2 bad motherboards....
  1. Need Help!- Spindle control problems with X2,G540,Mach3...
    By forrest39 in forum Benchtop Machines
    Last Post: 01-03-2013, 08:42 AM
  2. New Machine Build- G540 problems and support
    By chuck1024 in forum Gecko Drives
    Last Post: 01-07-2011, 09:06 AM
  3. g540.xml ????????????
    By breathe in forum Open Source CNC Machine Designs
    Last Post: 08-31-2010, 08:24 AM
  4. G540 PWM
    By mikie in forum Gecko Drives
    Last Post: 05-21-2010, 01:50 AM
  5. g540
    By Scooby Doo in forum Gecko Drives
    Last Post: 05-17-2009, 02:44 PM
