Results 1 to 5 of 5
Thread: Is this a deal?
    Jun 2004
    Is this a deal?
    I've been running my home made cnc for a while now, and just recently got into machining metal. I've been looking for bits 1/4" and under for a while, and stumbled upon an e-bay deal that might work, might not. Y'all tell me.
    Minature solid carbide end mills 1/32 to 1/4 dia. | eBay
    Mar 2007
    If by "metal" you mean aluminum AND your machine is rigid enough to machine aluminum and your spindle has plenty of torque at lower RPMs, then the answer is "maybe", lol. That particular auction does not list the sizes, flute count, quantities or conditions of the bits in question. I would suggest you "ask the seller" to list some details about the bits before you OPEN the bidding @ $70. For example if 20 of the bits have 3/16in shaft diameter and you can't get a 3/16 collet for your spindle then you might not be very happy. Again, if the majority of the bits are truly "minature" (sic) then there are likely better deals to be had. I have bought a few lots of 50 1/8in shank carbide bits for under $50 (one set 4-flute "roughing", the other 2-flute). On the other hand, if they happen to be mostly Made in USA 1/4in ball and straight end mills in "like new" condition then it could be the deal of the century. I would think you would want mostly 1/4" and 1/8" straight bits, that is certainly what I use the most of. You will find out very quickly if your machine is rigid enough for them ;-)
    Hope that helps,
    Fish
    Registered fizzissist's Avatar
    Apr 2006
    If they are in fact new, it's a helluva a deal at $70.
    Not new? It's a crap shoot.
    Jan 2006
    Additionally, its better for you not to "broadcast" the great deal you found on ebay before its over. You are just advertising it to other possible competitors which will make your price go up.
    Good Luck
    Matt
    Apr 2006
    Quote Originally Posted by wbegg View Post
    Some of the mills are Brubaker 91145's, single end, solid carbide, uncoated, 4fl, 1/32", that retail for around $9.
    I might bid on the lot...thanks for the tip!
    1. Deal or No Deal? Stepper driver package.
      By voltsandbolts in forum General Electronics Discussion
      Last Post: 05-11-2010, 10:35 PM
    2. Deal or no deal Lathe
      By _taz_ in forum Mini Lathe
      Last Post: 10-16-2008, 12:53 PM
    3. What do you think of this deal??
      By zoeper in forum Bridgeport and Hardinge Mills
      Last Post: 07-02-2006, 09:17 PM
    4. A Done Deal
      By CRFultz in forum DIY CNC Router Table Machines
      Last Post: 05-20-2005, 07:26 PM
    5. Not a bad deal....
      By anoel in forum DIY CNC Router Table Machines
      Last Post: 10-21-2003, 11:51 AM
