If I read your post correctly I believe the minimum answer is the length of travel + the distance between the mounting blocks of your moving gantry. This assumes that your spindle is mounted in the center of the gantry. You should add something in rail length for error, over run, limit switches, etc.
Correction: + the width of the gantry, not one half.
Robert
LinkBack URL
About LinkBacks
